Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. 64 DODGE 440
    64 DODGE 440
    from so cal
    Any time you have more than one, one will turn it off after the first one turns it on. Murphy was an optimist. :p
  2. CGkidd
    CGkidd
  3. Well it wasn't as easy as I thought...........
    hummmm we have torque.............
    Getting ready to do some investigation.....
    Hummm catch pan has trans fluid, not a good thing pan is primer color..... humm..........
    time to pull this pig apart...........
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    Humm this don't look right..............
    Time for an upgrade......flex plate ain't too pretty either.......... Grrrrr
  4. 64 DODGE 440
    64 DODGE 440
    from so cal
  5. 29AVEE8
    29AVEE8
    Carl.
    Owning a race car is a disease, their is no cure, and the only known treatment is very expensive. Parts failure grows exponentially with power produced. Sorry for your misfortune.
  6. Damn, Carl, that converter should have floated off when you split the trans loose you balooned it so much! But seriously, sorry about the bad luck. The purple paint makes it look like a P.I. converter, was it?
  7. wrenchbender
    wrenchbender
    Well carl that sucks and I wish I didn't know how you feel lol just be glad it didn't come completely apart I would certainly check the entire Trans Real good to make sure it didn't tear anything else up its been said already racin breaks stuff lol more power more broken parts lol ask me how I know lol
  8. CGkidd
    CGkidd
    Damn that sucks Carl.
  9. old sparks
    old sparks
    If it will help, I take back the bad luck part. I hope that all you need is a convertor and a trans cleanup. Wish you well
  10. Na not a PI, its a Flat-O, gonna get it beefed up though...........
    yea it may suck but that's racin, so on to the next step......... one step at a time:D:D:D
    just want to make sure I get er back for Eagle in oct and maybe a T&T before that to get carb right.
    sure felt good on that last run though:D:D:D:D:D:D:D:D:D:D
    Now if we can figure out that damn GoPro
  11. dragsled
    dragsled
    from Panama IA
    Keep on Truckin Carl, Too bad about the trans
  12. Yea Tim but just wait till get er back together and spend some time tuning her!!!! knockin on 10's finally!!!!Wahooooo
  13. Well at it again while we are down waiting for new flex plate...... wasn't really happy with belt alignment sooo made new shim for under blower and re did the brackets now really happy
    Tapered plate 1/4 x .085 ..........before finish holes
    However had shavings all over the shop..... damn I hate that.......
    [​IMG] [​IMG]
  14. 64 DODGE 440
    64 DODGE 440
    from so cal
    Don't forget you need to make a belt guard too. :rolleyes:
  15. Yea Tom that's in process already........
  16. 64 DODGE 440
    64 DODGE 440
    from so cal
    Make it pretty. :p
  17. dragsled
    dragsled
    from Panama IA
    Well Carl,, I see your back to just sitting around watching the grass grow:D:D:D
  18. Well once again I want to give a Props to Gene Benson and Flat-O out of Salem Oregon sent him the parts repairs were made posthaste and back in my grimy little hands already, man that's service. Over the years Gene has been one stand up business owner and its wonderful to see that in this screwed up world of ours. Anyone needing flathead C4 parts should look him up.............
  19. dragsled
    dragsled
    from Panama IA
    Great to hear you'll be back in bussines soon
  20. Well time to put er back together!!
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    And she's back where she belongs...........a few more things to put on and we can fire er up tomorrow......
    Had to make some weld nuts as I didn't want to buy them.........and the beat goes on
    9sectruck likes this.
  21. dragsled
    dragsled
    from Panama IA
    Good to see Carl
  22. loudbang
    Perfect "time lapse" shots of the evolution of a clean "t" shirt to a normal garage one.
    1947knuck and tomkelly88 like this.
  23. 64 DODGE 440
    64 DODGE 440
    from so cal
    Another reason I don't wear white t-shirts very often. :D
  24. Whats this look like to you......
    looks like a blower belt guard to me...........
  25. 64 DODGE 440
    64 DODGE 440
    from so cal
    Is it done yet?
  26. Yep Tom.........
    Parts is parts.....
    [​IMG] [​IMG]
    [​IMG] [​IMG]
  27. CGkidd
    CGkidd
  28. That's too darn purty for a safety device.
  29. "TO EAGLE AND BEYOND"
  30. cowboyinachair
    cowboyinachair
    from colorado
