Technical SBC Identification
Discussion in 'The Hokey Ass Message Board' started by Littledeucecoupe, Apr 23, 2024.
  1. Littledeucecoupe
    Littledeucecoupe
    For my 54 GMC project I was given a old SBC and a TH400 to keep my project alive.
    Date code F158 so June 15 1968
    Casting number 3970010. Usually seen on 350s yet a 350 was not available in 68? So 327????
    Serial and Vin Code
    I know it's a Saganaw Cast due to the clock. Shift 1 7 hours in to the shift according to my Chevys By the numbers.
    The T8 on the serial tells me T= Truck and the 8 again for 68.
    Has a huge Harmonic Balancer and and equally large and pushed forward crank pulley
    Heads gave slightly angled plugs and rounded square ports on the exhaust.
    Has an aftermarket intake, has not had a vlave cover pulled yet to get head casting.
    The T?S is confusing is that a D or a backwards C? Nothing I have found notes a TDS if it's mis stamped.
    Also having the stamp above and below is not like any I've seen, usually it's all along the edge in a line.
    I know it's not a 78 motor as again according to my book in 70 they started stamping 70,71 etc to note the year not just the last number.
    The 3970010 is equally strange being a 68 block.
    Far as I can tell this might be a Large Journal 327 C10 motor??
    What says the actual experts of the HAMB?
    Unknown what it really came out of as buddy who got it rescued it from a crashed SBC swapped Jaguar.
    All I know it's no DZ. Lol!!!
  2. squirrel
    1978. Not 1968. The two digit year on the casting date was a random thing, you can find single or two digit years over several decades.
    The short number pad is a big clue that it's a later 010 block, not an early one.
    The three letter suffix TDS is another big clue, they started using three letters in 1970, and most of the Chevy cars started with C, most of the truck motors started with T. This is a GMC engine, since the first character of the partial VIN is T, not C
  3. Littledeucecoupe
    Littledeucecoupe
    Thanks Squirrel so it's just a run of the mill 350? At least it's a GMC motor going in a GMC.
    Deuces and SS327 like this.
  4. Mr48chev
    I've got it's twin out in the garage, At least the short block. Came out of a 78 truck that my buddy horse traded for to get some part out of and I got the engine that I did a rings, rods, mains and valve job on.
    Then I wore out again and this time it needs a full rebuild.
    The big damper is a good thing, don't toss that out.
    Littledeucecoupe likes this.
  5. Littledeucecoupe
    Littledeucecoupe
    Any clue if it's a 4BM? Probably just a 2BM but one can only hope.
  6. DDDenny
    Actually the 350 was first introduced in 1967 for the Camaro SS.
  7. Littledeucecoupe
    Littledeucecoupe
    But not with the 3970010 casting? I should of clarified.
    Also nice Deuce HB. Old man built a 29 HB roadster back in the early 90s. Scratch built the frame to be different.
  8. squirrel
    Most of the truck 350 010 blocks were 4 bolt mains. If you care, drop the pan and see.
    Deuces likes this.
  9. Deuces
    Deuces
    Yep! I'm curious also....o_O
    Pull the pan please.... And post a picture er 2....:)
    You might even have a forged steel crank if your lucky...:cool:
  10. Littledeucecoupe
    Littledeucecoupe
    Be a while till I can get the pan off. Not looking for a crazy radical build but 300-325 horses will make me smile. Open 9" diff or I'd go crazy, bit it is a big bearing 31 spline big axle 9".
  11. squirrel
    I'd put the odds of 4 bolt at 95%, and the odds of steel crank at 5%
  12. HEATHEN
    HEATHEN
    from SIDNEY, NY
    When I worked in a parts store that also had a machine shop in one end of the building, someone bought a rebuilt 350 for their '72 C60 truck, and when they dropped off the old engine for a core, I was thinking, "Great! I'm going to latch onto that one and get a forged crank!". Ran the numbers...and it was originally out of a '70 Impala with a 2 bbl and a Powerglide.
    Deuces and squirrel like this.
  13. Littledeucecoupe
    Littledeucecoupe
    Head stamping
    Deuces likes this.
  14. squirrel
    that last picture shows why you should not use gaskets with manifolds on chevy engines... :)
    624 heads are pretty crappy, as chevy heads go. But they'll work ok if you're not too worried about performance.
    Littledeucecoupe and Deuces like this.
  15. Littledeucecoupe
    Littledeucecoupe
    I have read the heads are prone to cracking. So I am probably going to have to find some aftermarket heads if I want reliable power.
  16. Littledeucecoupe
    Littledeucecoupe
    @squirrel eighten me on the gasket thing. Truly curious as you are not the first person I've heard that from over the years.
    If all goes forward on this and it will thisotor will probably now end up with some decent low end heads and long tube headers or at least some block huggers.
  17. squirrel
    Chevy didn't use gaskets between the head and manifold. They're not needed, and all they do is insulate the parts from each other, limiting heat transfer, then the manifold gets too hot, especially between the center exhaust ports.
    but gasket sets come with the gaskets, so people install them.
    Headers need gaskets...
    SS327, 283john and Littledeucecoupe like this.
  18. Beanscoot
    Beanscoot
    Fords also did not use exhaust manifold gaskets, somehow I got the idea to use graphite grease as a sealer.
    I think a lot of broken manifolds can be traced to the use of gaskets, and the uneven disintegration of those gaskets combined with retightening of the bolts.
    Littledeucecoupe and Algoma56 like this.
  19. Littledeucecoupe
    Littledeucecoupe
    Best to have the surfaces decked of you rebuild and plan on running manifolds vs Headers?
    One shop project we got a set of Hedmanns and could not get the things to seal even with those thick heavy gaskets. It would blow them out in mere miles. Found the flange was nowhere near ture for brand new. They wouldn't swap them out since we installed them. Tried to have the face decked but they couldn't get it in the machine. I did my best to flatten it but ended up taking a slab of 3/4 plate made a jig heated the flange cherry red and bolted it to that slab of steel. Let it cool over the weekend. Never had an issue again. Other than you can't keep paint on the dang things even high temp. Lol
  20. I have basically that same engine in my 52 GMC (see avatar), although out of a 76 truck. It runs fine, reliable as a rock, only leaks a little bit of oil. Old Edelbrock dual plane alum intake with a Q-jet and rams horn manifolds dual exhaust. The heads are not the best for performance as noted, I keep debating myself to upgrade to better heads, or just go with a whole 383 new engine. The 383 would have better power and be roller cam to eliminate the oil issues. But for now, I drive all over the place and it is tough to beat a good running old 350. While needing to do work on my other old cars.
    BTW, no idea if mine is 4 bolt main or steel crank. Never looked inside the pan, or paid enough attention to the crank flange when installing it about 12 years ago. It was a good running engine that was available to use, so it got chosen to be put into the 52 GMC.
