Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. Ned Ludd
    Ned Ludd
    I regard the automobile as having become extinct around 1990.
    timberwolf01 likes this.
  2. fredvv44
    fredvv44
    I heard that no US manufacturer is building a gas powered sedan anymore.
  3. noboD
    noboD
    That MAY change in Jan.
    porkshop and The37Kid like this.
  4. timberwolf01
    timberwolf01
  5. banjeaux bob
    banjeaux bob
    from alaska
    porkshop likes this.
  6. Ned Ludd
    Ned Ludd
    The corporate agenda drives the politics, not the other way round. Our kind of cars are dead because they aren't what the industry wants made. They are a threat to the desired radical monopoly.
  7. fredvv44
    fredvv44
    That was an interesting read. It has long been recognized that Detroit sells us what it wants to make not what we want to buy. The import market made that point quite clear.
    Ned Ludd likes this.
  8. timberwolf01
    timberwolf01
  9. timberwolf01
    timberwolf01
    Caption: The starting line at the Grand Prix de L'ACF des Cyclecars, Amiens, France, 1913. In car number 25 is J Ronteix, in car number 26 is Jolibois, and in car number 27 Francis. Ronteix finished third, Jolibois seventh, Francis did not finish.
  10. timberwolf01
    timberwolf01
  11. timberwolf01
    timberwolf01
    The Violet-Bogey driven at Le Mans 1913 (Grand Prix de l'UMF. des Cyclecars) by Marcel Violet, who finished second.
    porkshop and Ned Ludd like this.
  12. timberwolf01
    timberwolf01
    1913 Violet-Bogey
  13. timberwolf01
    timberwolf01
    1913, July 13, Amiens, sidecar and cyclecar grand prix, Pouliez on Violet-Bogey, Canoriel on Sphinx-Globe
  14. timberwolf01
    timberwolf01
    Violet-Bogey gear change: the friction roller G is applied against the plate P driven by the motor. G moves laterally on the ribbed axis A under the action of the triangulation N maneuvered by the pilot using the lever L. The neutral point is obtained when the roller G is in the middle of the axis A, aligned with the center of the plate P. The greatest speed is obtained when G is at the edge of the plate, as for example in the photo. Sliding to the left beyond the center of the board is in reverse. At the left end of the A axle is the sprocket that drives the C chain to the rear sprocket attached to the wheel axle (no differential).
  15. Ziggster
    Ziggster
    Very interesting concept.
  16. mohr hp
    mohr hp
    from Georgia
    My neighbor had a snapper lawn tractor with that type of arrangement. The flywheel was rubber coated.
    Ned Ludd and timberwolf01 like this.
  17. banjeaux bob
    banjeaux bob
    from alaska
    styled somewhat similar to Jay Leno's Shotwell. Imagine it being powered by a gas engine instead of an electric motor.
    porkshop and Kume like this.
  18. Ned Ludd
    Ned Ludd
    Most commonly associated with the British GWK light car:
    porkshop, Kume, G Baese and 1 other person like this.
  19. fredvv44
    fredvv44
    At least try to get the proportions close!! View attachment 6039447
    I've had a couple of Snapper lawn tractors but they both had plane flywheels and rubber coated driven wheels.
  20. timberwolf01
    timberwolf01
    Proper gearbox! :D
  21. mohr hp
    mohr hp
    from Georgia
    Maybe it was the other way around like that. Been over 20 years! It worked. Infinitely variable drive and pretty simple.
  22. banjeaux bob
    banjeaux bob
    from alaska
  23. AnimalGuy
    AnimalGuy
    I have always built odd cars.
    This time around I'm building a Mini Gasser using a 37 Ford Legends car and will use a St or CTX1300 engine.
  24. fredvv44
    fredvv44
    That will be cool. I always liked the gassers and especially the Altered class. It was so crazy watching them go all over the track. They looked like a GN racing.
  25. banjeaux bob
    banjeaux bob
    from alaska
    11174646_10206737815352933_591305610054980881_o.jpg "Rocket car", Johnstown, USA.
    porkshop, fredvv44 and j hansen like this.
