Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 06-05-2012, 09:45 PM   #1
poncho55
FNG
poncho55's Avatar
Default Pertronix - convert from Positive ground to negative?
Hi, I have changed my generator over to a 100 amp alternator as I was sick of the smell of the smouldering regulator. The problem that I have now is that the car needed to be converted to negative ground (done), but now the Pertronix Ignitor that was in the distributor is not throwing any spark. I checked the connections and I thought that I could just change the connections. Before I just did that and faced frying something, I threw a note over to the good people at Pertronix and they mentioned that I need another kit with Negative ground set up. I would rather not have something else sitting on the shelf that I can't use (original unit) - anyone done this same conversion and then used the same Pertronix kit that was for a positive ground?
Help!!
offline   Reply With Quote
Old 06-05-2012, 10:25 PM   #2
Buddy Palumbo
Senior Member
Buddy Palumbo's Avatar
Default Re: Pertronix - convert from Positive ground to negative?
I can't speak for your exact car , but on the cars I restore (vintage british tin) it uses a completely different Pertronix unit for positive and negative earth - even gets wired completely different .
__________________
~~~~~~~~~~~ Allen
Old 06-06-2012, 07:39 AM   #3
poncho55
FNG
poncho55's Avatar
Thanks Buddy, that is kind of what I was afraid of! Will try and get a new one fast.
Old 06-06-2012, 10:54 AM   #4
hotroddon
Alliance Member
hotroddon's Avatar
Yes, the negative ground and positive ground Ignitor's are different. And hooking up the old positive ground one to a negative ground system undoubtedly smoked it.
Don from PerTronix.
__________________
HOT RODDING - It used to be about the cars, now it's just a freakin Fashion Show
online   Reply With Quote
Old 06-06-2012, 12:09 PM   #5
d2_willys
Old School HAMBer
d2_willys's Avatar
Quote:
Help!!
Would really be nice to know what vehicle had the generator!
__________________
Dual range hydros rule!
Wise man say to 53 Olds with Dynaflow owner: SHIFT TO LO & GO!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
