Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1021 |
Alliance Member
__________________
My shop that pays the bills...kristkustoms.com My "sister" company...doublekoriginals.com I'm always looking for upholstery work on traditional hot rods! |
#1022 |
Old School HAMBer
your shop floor is much prettier than mine lol floor envy
__________________
#1023 | |
Senior Member
I drilled and put 4 lag bolts in the floor..Have a portable hand winch that can be used on our trailer or pinned to the floor.
beats the hell out of pushin crap in & out. Rick ========================================= Quote:
#1024 |
Grenade Inspector
#1025 |
Senior Member
new shop stool
PADDED! |
#1026 |
Old School HAMBer
#1027 |
FNG
lmfao
#1028 |
Old School HAMBer
These days it needs to be heated too! Damn, I wish someone would turn up the heat around here.
__________________
"Remember Professionals built the Titanic, An Amateur built the Ark." |
#1029 |
Alliance Member
Here is a hanger I made for the air tools. Real simple, yet SUPER functional!
Here is a hanger for the clamps + some background art (most from the HAMB) And the last one is the Vice stand. Semi wheel split. 4" vertical pipe with 1/4" wall and then a 1/4" plate on the top. It has holes cut for mounting my bench grinder when needed.
__________________
1941 Chevy 2-door Sedan |
#1030 |
Old School HAMBer
how do you hold that thing down when you're really busting the hell out of something?
__________________
#1031 |
#1032 |
If Von doesn't have it secured to the floor he could gain some stability by rotating it 90 degrees and leaving it cantalevered the way it is.
I have had vices that I used to hold projects for welding grinding and drilling that were mot secured any more than that. My favorite vice however is one that weight about 50 lbs. and is mounted to a 150 lb cast iron base that is broad at the bottom. I have still tipped it a few times when trying to straighted or bend material. Dick
__________________
dawford If the first Hot Rodders were all Traditional we would still fuel with oats and hay. |
#1033 |
Alliance Member
No offense to Voh's work, as it's real nice. But the worry about stability isn't too imporant, considering the choice he made for a vise. It's not gonna hold anything much if any tighter than the unsecured mount holds the vice.
I have one of those vises on one end of my 2000# steel topped worktable. I've bought a big old 100# vise used, and it's on the "to do" list to swap them out, The pictured vice tries to do all things holding all sorts of metal shapes in all sorts of positions, and consequently doesn't hold any of then very well, plus the swivels won't resist swivelling very well when you try to lock them down. Dave |
#1034 |
Old School HAMBer
Quickie portable winch for loading and unloading trailers:
It's the HF 200 0lb 12v el cheapo ATV winch (I was surprised that it was better than I expected), aluminum plate, tow hook and a wide angle iron mount for the fairlead. Built from scrap on hand. I tried it out this weekend to pull a cement mixer up into the bed of my truck. Worked fine. I am going to add wooden lateral skids to help steady it but wanted to see how it worked first. Note: It is not attached to that plywood; it is just sitting there. |
#1035 | |
Grenade Inspector
Quote:
That's exactly what I had in mind, with that $49 HF 2000 lb atv winch! I didn't know if that winch would hold up, so thanks for the little review ; ) I was going to attach the winch to 2 2"x4" boards (stacked & bolted to make 1 4'x4' for rigidity), run horzontally and attached at the front stake posts behind my pickup cab. Then winch up the heavy items on atv ramps. Once I get 240v in the house I am at now, I will eventually weld up a steel horizontal piece, and attach it to the bed sides with grade 8 bolts.
__________________
"Beer is proof of Gods love for us" - Benjamin Franklin
#1036 |
Location: 3rd. house on the right., behind the big oak tree, across the street from the hoarders, in NJ
I need some large wrenches for an OT home project.
So here's what I came up with. Yup, they're made from plywood, and worked great ! ![]()
__________________
Up for sale soon: 1958 392 Hemi (58N11157) |
#1037 | |
Old School HAMBer
Quote:
The stake holes on my truck are covered with a bed liner. So here is how I secured the front of the winch: I took a long rope and looped it under the frame between the cab and the bed. The rope went up between and then over the front edge of the bed. Rope against bed liner did no damage. This is strong enough to pull up a cement mixer (as I did) or a quad. It also gives you a better angle as the winch sit in the dead center of the bed and the rope angled down, then a straight shot down the ramps. Your plan will work, too, and I might well have done it that way if I had access to the stake pockets. |
#1038 |
Old School HAMBer
#1039 | |
Quote:
Pond filter system using "plastic" 55 gal drums
__________________
#1040 |
Alliance Member
Never could afford one of those fancy sandblasters!
| Thread Tools | |
| Display Modes | |
