Projects my 1950 dodge wayfarer rebuild
Discussion in 'The Hokey Ass Message Board' started by 50FREAK, Apr 25, 2010.
  1. 50FREAK
    50FREAK
    got the car from my uncle & finaly got it almost how i want it[​IMG]
    how it looked when i got it
    workin on the air bag set up
    buildin a 2 link
    not too bad..
    layd out on the old wheels
    layd oun on the stock wheels
    merc rings
    ring tacked in place
    filler to blend the ring
    filler tacked on
    fully welded
    welds all grinded down
    all blocked down
    jams all done
    color change..
    home from gettin sprayed looks sooo much better than pink & red
    side view aired up white walls comin soon
    front view
    layd out with the new look all black frenched headlights
    thanks for checkin it out!!!
    let me know what you all think about my progress so far
    P.S. istill plan to build a new frame so the body will lay all the way flat on the ground and ill get updated brakes in the process i also plan to chop the top a couple inches
  2. 88daryl88
    88daryl88
    Nice work... looks a LOT tougher than in pink & red.
  3. 50FREAK
    50FREAK
    haha yea thats what i was tryin for
  4. Lookin' good.
    Is it still a flathead six, or what engine??
  5. 50FREAK
    50FREAK
    yea its still a flathead 6 with a fluid drive trans (clutch & torque converter)
  6. scrap metal 48
    scrap metal 48
    I like it; much better......
  7. atomickustom
    atomickustom
    You're going to build a whole new frame so that it can sit an inch or so lower when you air down??
    I think the car looks good the way it is and I wouldn't go to that much trouble for such a small gain.
  8. 50 Wayfarer 2 dr sedan is my favorite car, yours is looking good. The "black on black" really fits the car.
    that said, why french the headlights and then NOT go any further? I see that it has the fender trim gone and the rear fenders welded, but what of the emblems, door handles etc?
  9. 50FREAK
    50FREAK
    bildin the frame will drop the car a good 3" - 3 1/2" and also brake parts are so expensive for this car.. i Spent $750 to rebuild the brake system and the brakes still suck.. for 750 i could have built my frame & bought some PBR to quench my thirst while buildin the new frame... but those are future plans not for atleast a year or so... far as the trim and door handles go i just like the lil bit of trim probably shave the handles once i convert it to 12v
  10. RodStRace
    RodStRace
  11. DirtyWoody28
    DirtyWoody28
  12. GEBHARD
    GEBHARD
    from TX...
    much better....looks good!
  13. Very nice, the only thing I like pink is *cough* and prime rib.
  14. el conejo 1964
    el conejo 1964
    looks great....(now change that avatar...my eyes is burnin!)
  15. 50FREAK
    50FREAK
    i dont know if ill do skirts.. but i want to lower the wheel openings like 3-4" in back and 2" in front
  16. 57JoeFoMoPar
    57JoeFoMoPar
    Looks much better, but you are going to paint it right?
  17. DRUGASM
    DRUGASM
    It sure looks alot "better" than when you got it....as in more traditional. I dig it man....
  18. "Whitey Ford" 62 Uni
    from Tampa, FL
    Thanks for saving it hahahaha Looks WAY better.....i think some wide whites and shiny paint are in order though. Flat black never shows the lines as well.
  19. TagMan
    TagMan
    The car looks great now!
    How stiff is the ride with those ladder bars?
  20. zmcmil2121
    zmcmil2121
    Cool, I kinda think it looks cooler with the pink and red but that is only because the colors added to the body and it's lines and added something else to the over all car.
  21. freebird101
    freebird101
  22. James Curl
    James Curl
    I did disc fronts on my 48 Plymouth which has the same spindles for under $500.00 using all new parts. I also used a 90 Dakota 3.55:1 rear axle and brakes. Most pick and pulls have the complete rear end for around $100.00 which gives you separate drums from the axles on the back. You have to change the spring perches but since you are bagged you could have just put the brackets on a Dakota rear end. I believe the Durango uses the same rear end and some of them have disc brakes on them. I got my adapters for my front from Rusty Hope or as he is also known as old daddy. I think you can find him here on the H.A.M.B. under old daddy. He also makes a shock relocation bracket to move the upper shock mount to the frame instead of the upper A arm. You might try looking at www.P15-D24.com which is a site for 46/48 Plymouth and Dodges but they welcome anyone with a flat head MoPar and some with SBCs in MoPars through 55, I am a member there also and there is a wealth of knowledge there. Their home page has all sort of vendors and services and suppliers plus all the specs and more.
  23. pro1street
    pro1street
    Here's some widewhites with spidercaps and some paint and skirts for it.
  24. R Frederick
    R Frederick
    from illinois
    Thanks for saving that car from streetrod hell. I had a line on a Wayfarer five years ago, but the seller backed out. You might want to consider painting the fenders or two tone the lower part with a gloss black. It would be TONS easier to maintain, and give it a look like "it is done". Please, no skirts. Trim level looks just right. I really don't think "layin frame" is really that important, really?
  25. 50FREAK
    50FREAK
    THANKS FOR ALL THE FEEDBACK!! the car still isnt finished. this isnt the final paint im going back & fourth with black & root beer brown.. but i just wanted to get rid of the pink & red it had alot of chips & scratches & i didnt want primer blocks on the front from frenching the headlights, also cant afford all new window rubber for the final paint rite now.. the ride is pretty good still with the link setup in the back comparable to the stock leafs a lil softer probably.. but slam bags are pretty stiff a firestone would be more squishy but i like the slam bags better & they are made localy.. & thanks pro1street for the photo shop i actualy looked at a green close to that it comes on a newer toyota
  26. wayfarer
    wayfarer
    It's looking good.
  27. TiMe_1
    TiMe_1
    from clovis ca
    Its OK......:D
  28. rokcrln
    rokcrln
    I think you will find if you get the slam bags off the diff and mount them on the links you will get a much better ride. Convoluted bags are not meant for a 1:1 ratio like you have them but more of a 1.5:1 ratio. Now a sleeve bag would be great for on the axel set up. I run slam RE-5,6,7 on almost everything I build and they always ride great as long as they are set up to the correct ratio. Also it is very important to have the right ride height for the bag to get all the comfort out of the ride.
    By the way the black looks great!
    Kevin
    LFD Inc.
  29. phukinartie
    phukinartie
    Nice cleanup!!! I am glad you are gonna put color on the car though...Primer is just so overdone these days
  30. rrbrucea
    rrbrucea
    The frenched headlights look fantastic on that car!
