Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#21 | |
Alliance Member
Location: Niagara Canada. The deep south of the far north
Quote:
__________________
SFCC... we can do it ourselves. (Canadians use thicker socks) My shoebox build... http://www.jalopyjournal.com/forum/showthread.php?t=626123 |
#22 |
Newbie
yeah posies makes 3" lowered springs - be sure to get part # 440A if you're using a later model axle - they will center the wheels.
#23 | ||
Quote:
Quote:
Sure, a 4 link air bag set up would be nice, but for my first build I am going for somewhat affordable and easy. |
#24 |
Got everything (engine/trans/rear axle) loaded on the trailer and its off tommorow to the shp, hope it all checks out ok. I pulled the rear leafs out and saved all the junk, but will be going back with posies out back. I found some camaro coils but they are cut. I am going to throw those in just to get the frame mobile after getting the rear axle back, then take it for blasting.
I firgured I would strip the frame completely once I get it out from under the cab and take it to them bare, with the rest of the stuff I want blasted in boxes. Are there any precautions I should take as far as what can be blasted. Will they actually be "sand" blasting or using some other media, or is that something that is determined by what you are having cleaned? What about the blasters you can buy at, say, tractor supply? Are they worth it, do they do a good job, etc. I thought about buying one of those and laying down a tarp, then maybe erecting a canopy type deal with plastic sheet sides to make a sort of booth to cntain the mess, is that feasable? |
#25 |
Alliance Member
At least slap him around a little, maybe thump his woman,,,,
#26 |
Sounds like your making good progress there. More pics?
#27 | |
Alliance Member
Quote:
__________________
Only the good die young. If you want to live a long time, be an asshole. " I am attempting madam, to construct a Nemonic memory circuit using stone knives and bearskins " |
#28 | |
Newbie
Quote:
440A Springs - $345.95 455 - Spring Eye Bolt - $34.95 450 - Rear Shackles $84.95 8003 - U Bolt Plates - $18.95 8002 - U Bolts - $25.95 For the U Bolts and Plates remember to measure the diameter of your axle. |
#29 |
Grenade Inspector
I was in the same boat with my 50. I hated the way the clip was done so I ended up scrapping the frame and starting from scratch. The only thing ive kept from the original truck was the cab and engine/trans. Live and learn I guess. Good luck with it.
#30 |
Alliance Member
Did I miss somthing here, it sounds like you bought a truck that wasnt finished and you are suprized that its needs work? Im not trying to be an asshole, its just how I read this.
#31 | |||
Quote:
Quote:
Quote:
#32 |
Senior Member
Don't slap him around, steal his tools. Then you can show the judge the pictures and claim it was in the name of public safety.
__________________
If I call you a tool, don't assume you are useful.
#33 | |
Alliance Member
Quote:
#34 |
Grenade Inspector
I'm going to watch this thread. I'm going through something like you with my 54. The previous owner loved taking shortcuts. Having to do everything over makes you learn a lot though.
-I learned that bondo is the cure-all for autos. everything from cab corners, dents, holes and anything else. - I learned that you don't need to wire your cars with a harness, you can just electrical tape everything. - I also learned that it's cool to use a wood 2x4 for a cab support. (that one pissed me off) I am sure that is just the start, as everything isn't apart yet. Good luck with your build, keep plugging away at it. At least you're taking the time to do it right. just keep your eye on the prize and think of how bad ass it will be when you are cruzin it. |
#35 |
Thanks guys...
So half ass find #55, the trans crossmember is apparently too far back for the engine/trans combo, or they welded too much of the front clip on, and instead of moving the crossmember or fabing one the welded a plate to the back of the trans mount, drilled 4 holes in it and bolted it up. I didnt notice it at first, but when I took the bolts out this big plate fell out, and when I got it to the shop today I saw the broken weld on the back of the mount......sheesh.... |
#36 | |
Quote:
#37 |
Great thread so far.
I just love P.O.'s. People that work on cars with out a clue. It's a good thing you bought this truck. Some kid could have bought it and tried to drive it!. No rear brakes at all!! Are you kidding me??? |
#38 |
FNG
#39 | |
Alliance Member
Quote:
I stripped it completely bare before taking it to the blaster, less work for him = less money he charged me.
__________________
#40 |
Well. Pulled the rear diff cover and man was it nasty. First of all, full of water. Second, open diff. Again, all fixable but for crying out loud!!! Phone is dead so no pics, but there is surface rust on stuff and stinks bad, grrr.
Ok, so rear locking diff, rebuild kit, rear shoes and wheel cylinders, resurface drums, clean/blast and repair housing and figure out if the spring saddles on there right now will work with the new leafs I am ordering. Agreed, one of my techs says he will let me use his blaster, so I will strip it down and do the little stuff with that and get the frame done by the pro's. |
| Thread Tools | |
| Display Modes | |
