Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#121 |
Alliance Member
...And I was too smart to buy the Tom Saywer routine that Hot Rod Ron fell for! Well, kinda... Hey, what the hell you doin' on the H.A.M.B.? Aren't we goin' to Austin?
#122 |
Old School HAMBer
Uhhhm, wrapping up a few loose ends.
#123 |
Alliance Member
That is one world class table. I like the idea of being able to bolt the fixtures to it like that as I've seen a couple of them that they would weld the uprights to and then cut them off when they needed to change position.
__________________
Definition of a "work car". One you have to work on all weekend so you can drive it to work the next week. |
#124 |
Have fun in Austin guys! What an amazing table. If I ever manage to buy a house, I may have to have you cut me some less fancy legs.... If you need me to stop by the shop, and check on the table, leave it some food/water, have Chip give me a call. I'll check on the dog too.
__________________
Build it, don't buy it. |
#125 |
Alliance Member
Are you suggesting that the table eats and drinks, or are you just confusing the table and woody? It has happened...
#126 |
Just judging from appearances, I would guess that that table drinks scotch old enough to order its' own scotch. I can always tell the difference with Woody, he barks just enough to make me think I must be a bad guy.
__________________
#127 |
Alliance Member
Steve that frame is gorgeous. Ok I totally understand the idea of being able to reach things and it makes sense for sure. I think I Need to start workin out and stretching more. haha Then I will be more flexible. I too thought of the Adjustable stand, but its a lot of work to move one up and down and keep it perfectly flat and squared. Each type of table has its own intended purpose. Buttttt A flat table like yours to me is more versatile than the others. I plan on having many fixtures to assemble parts so a flat table with jig areas is a must. Although for many an open table is perfect. You can build and mock everything up and leave it hanging off the sides or on the chassis without having to worry about it hitting the top of the table. Those tables to me are mostly for specific chassis building and dragster building. Anyhow thanks for the input. It won't be too long and My buddy Mike and I will be working on another table. Would be nice to have a water jet or plasma table too :P
In time things will fall into place.
__________________
Will '31 Model A 5 window "Most people spend more time and energy going around problems than in trying to solve them." Henry Ford http://vagabonds.cc/ |
#128 |
Grenade Inspector
When a man has as much pride in building his tools as he does his products, that's the sign of a true craftsman. Elpolacko proves he's a craftsman with everything he builds. Great work.
[Ass kissing/off] |
#129 |
Alliance Member
You hit the nail on the head with this. His tools and work is with out a doubt built with love and devotion.
__________________
#130 | |
Grenade Inspector
Quote:
"I broke out a long straight edge to see if the plate had any wave to it. If it did, I would make the surface concave a then weld the plate to the frame from the underside." you would make the plate concave with heat form an oxy acetylene torch? once the plate was concave, welding the plate to the frame would force the plate to become flat? Last edited by Joe Jackman; 05-24-2012 at 11:22 PM. Reason: removed photos |
#131 |
Old School HAMBer
Joe, please learn how to reply without linking all the previous photos. That shit is annoying and uses up bandwidth. You can cut them out of the reply box with a right-click drag, they will turn light blue and you hit backspace to delete .
#132 |
Alliance Member
Thanks T-Man, been trying to figure that out my self.
#133 |
Grenade Inspector
wasn't sure it was okay to do that. i went back and edited the photos out.
#134 |
Old School HAMBer
Jeeze Chip? I thought you were brighter!?!??!?! ![]() Seriously, I learn new tips weekly. Things like when you are looking for info on Oil Squirters for the pistons, just dont type OIL SQUIRTERS in the search window! Amazing what the human body can do!
#135 |
Alliance Member
Ha you give me too much credit sir! Now as to the other stuff, I HAVE learned how to operate browsers the girlfriend will NEVER know about, (crap, pretty sure 'Polacko taught me that too...) and I'm sure to what you refer to has several sights of it's own...
#136 | |
Old School HAMBer
Quote:
Nice work Steve, I've learnt to expect no less from all the projects you take on, be it workshop equipment of hot rod work. All ways great to catch up and thanks for the shop tour to boot.
__________________
THE MORE YOU LEARN, THE MORE YOUR REALISE YOU DONT KNOW!
#137 | |
Old School HAMBer
Quote:
Yes, when ever you heat steel and let it cool rapidly it shrinks. Ever done any sheet metal work with a stainless shrinking disc? |
#138 |
Grenade Inspector
#139 |
Old School HAMBer
Just type shrinking disk into the search window. MANY threads on here and the web dealing with them.
#140 |
Old School HAMBer
Tman is correct. There are several threads dealing with metal shrinking.
Try this for yourself. Set up a T joint out of scrap tube. Make it as square as possible and just tack one side with what ever welder you have available. Watch how much the weld pulls your T joint out of square. This pull happens every time you weld, or rapidly heat and cool metal. |
| Thread Tools | |
| Display Modes | |
