Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Grenade Inspector
Ok, I am really frustrated here. When I bought my '52, the door glass was cracked on both sides. I had a local shop cut the glass for me and I installed it. Less than 2 weeks later, the passenger side cracked again. I had it cut once again. Today the driver side cracked. I rolled the window down, cruised around a good bit today running errands, and it was cracked when I rolled it back up.
I am not slamming the doors hard or anything, and the glass company assures me that they are using the correct glass for the application... I do need new run channels and seals, but I'm on a tight (read: zero) budget and did not replace them. The original channels are in bad shape, but they are all there and the glass does not flop around. Any ideas?? |
#2 |
Senior Member
Money for new glass but none to replace the channels & seals?
Cut the glass & have then send it out to be tempered. |
#3 |
Im thinkin the glass is rattling around inside the door while your driving and then breaking. shouldent door glass be tempered? Sounds like you are describeing pane glass?
#4 |
Old School HAMBer
should be laminated safety glass ...and you need to fix the channels. I have heard of using the fuzzy side of velcro to line the channel but have not tried it yet.
#5 |
Grenade Inspector
The glass they used looks just like the original glass in the rear doors... it's two pieces with the green tint sandwiched between them. I'll have to ask if it's tempered or not.
I guess I'll have to spring for the channels and seals... in SC insurance pays for the glass, so it hasn't cost me anything so far... I've been putting all my money into a 292 inline six that will get swapped in eventually. |
#6 |
Old School HAMBer
my old 49 Chevy sedan had all new glass and fuzzys. it cracked all by itself while driving along minding my own business. when I gave it a close look I could see it was not polished well on the topside where they cut it. maybe your glass guy sucks?
there are glass people on here, maybe one will show up and answer. |
#7 | |
Old School HAMBer
Quote:
Not only do you need to replace the channels and the fuzzy strips along the edge of the door, you also need to make sure everything is aligned, adjusted, etc. The shop manual might help http://chevy.oldcarmanualproject.com...9_53/index.htm . |
#8 |
Alliance Member
Side glass should be tempered. It should shatter into 47 million square shaped pieces. This allows you to get out in an emergency. It shouldn't be plate glass or two ply safety glass.
Who know what it came with but what ever you are putting in isn't working. It also needs to be polished on the edges.
__________________
Thank you, I will be installing a breathalyzer on my keyboard the hamb relay network http://www.jalopyjournal.com/forum/g...hp?groupid=214 |
#9 | |
Old School HAMBer
Quote:
I'm not sure what type was available in '53, but laminated will be cheaper and easier to find, even if tempered is even available. Regardless, you need the channels to keep the glass from moving around and cracking or shattering.
__________________
We all tend to think that as we drive down the road in our rods or customs, that everyone who glances our way is admiring our car. In reality, the vast majority of people just don't get it. roddinron |
#10 | |
Old School HAMBer
Quote:
#11 |
you can have the glass co. make them out of 1/4" float glass, and have them send them out for tempering. or i vend in the felt door glass channels, and felt wiskers. any one you need. there 8 ft. $20.00 each plus shipping. JAN. the glass is going to make you broke if you keep breaking them. your call!!!
#12 |
Alliance Member
How are the window stops? If those are shot it's gonna rattle around. Glass doesn't like that.
Ditto on the channels and window stops. |
#13 |
Old School HAMBer
are you in the habit of slamming the door?
__________________
my favorite color is rust! |
#14 |
Grenade Inspector
I'm sure everything was adjusted properly, I installed them per the service manual and have done a good deal of glass work, just never on anything this old.
Guess I just need new soft parts to make it work, which was what i was thinking anyways and you guys confirmed it. Jan, I'll send you a PM when I have some cash to throw your way. Thanks a lot for the quick responses. |
#15 |
Grenade Inspector
#16 |
Grenade Inspector
Glass cracks when its overstressed - doesn't matter if its tempered, laminated, or plate.
You've either got some twist in the tracks or even the car door itself, or the tracks are too tight and pinching. The position of the crack may indicate the source of stress. If you want to be super cheap, try a layer of friction tape along the edges of the glass where they contact the tracks. |
#17 |
Senior Member
Nobody really hit on it yet but cranking too tight to close the window puts uneven stress on the glass (and even more overnight with temp change) and will crack any glass installation has to allow for movement ... check it in th "UP" position.
but either way you have laminate glass ... the tempered glass is cut BEFORE tempering (sent out) ..... which is the common product on newer cars Edit :ArchangelKustom ... good call on stress .... we be fast!
__________________
Generic response to any and all spelling Nazis, "Talk to my hand!" |
#18 |
Old School HAMBer
people are just used to new cars with tight seals and air tight passenger compartments.
__________________
#19 |
Grenade Inspector
Check the channel, the pieces are held on door frame by very small flat head screws. If one screw is worked loose and sticking out a bit your glass will catch its edge and a run will start. You dont need tempered glass unless you got money to toss. Find out what is wrong before you do anything.
__________________
Badlefthand |
#20 |
Grenade Inspector
Does the new cut glass have the corners rounded with a sander? or squared off as cut?
| Thread Tools | |
| Display Modes | |
