Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Alliance Member
I bought a 54 Chevy with an M II front end under it. At first, it was really scary. After some examination, I determined that the rack was lower than the tie rods and I was getting some ugly bump steer. So, I replaced the springs and presently the tie rods are parallel to the ground. I was afraid to cut another half round off the springs until they settled. I also put new napa M II shocks in the front and gas shocks in the rear.
I took it to the alignment shop Friday and it was aligned to the followings specs. 2.8 degrees of caster, zero camber and .2 degrees of toe in per side. I don't know how .2 degrees of toe correlates to 1/8" toe in but it should be close. The car definitely drives better but the straight ahead stability is still not comfortable. When driving on a secondary road, it tends to drive itself to one side or the other. Also, when you start to steer off center, it changes direction pretty quickly. The steering effort feels fine to me, not over boosted. Where did I go wrong? How can I get better Straight line stability?
__________________
You Can't Put A Price Tag On A Good Time! Here is my 41 Plymouth build thread. http://www.jalopyjournal.com/forum/showthread.php?t=498434 |
#2 |
Old School HAMBer
Would you please snap a picture, or two, of the setup, and post it?
__________________
Ala Kart had air bags in 1957. Traditional enough for me. |
#3 |
Alliance Member
If power steering I usually set up about 4-5° of Caster, and .5° negative camber, 1/8 toe in
__________________
HOT RODDING - It used to be about the cars, now it's just a freakin Fashion Show ![]() |
#4 |
Senior Member
If powersteering ,ford rack and a gm pump,sometimes you have to reduce the pump pressure
#5 |
Alliance Member
It is a power steering setup. Sort for forgetting to include that. I was also told it was a Fat Man set up with 2" dropped spindles. The spindles are in the center of the yoke, if that tells you anything.
__________________
#6 | |
Old School HAMBer
Quote:
Also, I once found that a prior installer had re-tapered the spindles so that the tie rod ends could be mounted the other way. I have no idea why, other than to possibly make use of the wrong tie rod ends. After correcting this, and re-aligning, it was just fine. Crazy sh!t happens.
__________________
#7 |
Old School HAMBer
Ugly bumpsteer stated in the opening post suggests a problem with placement of the rack and suspension components.
A picture of the front end would resolve the questioning. "If" the front end is set up correctly, there should be very minimal if any bumpsteer with the Mustang II suspension throughout the entire suspension travel range. |
#8 |
Alliance Member
ELpolacko, the tie rods are dead level with the ground now. Before, the rack was lower than the steering arms.
__________________
#9 |
Old School HAMBer
That's fine, but what is the relation of the rack to the lower control arms.
The inner rack pivot should be about two inches above the lower control arm pivot. If you squeeze the rack boot and feel for the knuckle of the inner tie rod joint, it should be slightly outside that same pivot. |
#10 |
Senior Member
If you draw a plumb line down from the lower control arm pivot, it should intersect the tie rod knuckle at the rack. Both sides. Does it?
Are the rack mounts nice and tight? Any slop in the steering assembly (with wheels off the ground, garb a tie and give it a push/pull to see if anything looks "loose")? |
#11 |
Alliance Member
There is no slop in anything. Here are some pics.
The better lit ones are with the car up in the air.
__________________
#12 |
Old School HAMBer
One of the things that kit builder do to make these front ends fit without much effort is spread the upper and lower control arms vertically. This makes the mounting points of the control arms taller than the spindle. This produces positive camber gain under compression and manifests as low directional stability.
Have your suspension alignment guy change your camber to .2 degrees negative on both sides. See if that gives you a better on center feel. |
#13 | |
Old School HAMBer
Location: Just past the corner of Hell and The Twilight Zone.
Quote:
.2 degrees is .0977" over 28". |
#14 | |
Old School HAMBer
Quote:
Would a little more Caster help ? |
#15 | |
Grenade Inspector
Quote:
I have MM2 on my '49 chevy truck and its a dream. You need more caster to get better straight line handling and the camber can be a little pos or a little neg, but I never set it at "0". |
#16 |
Old School HAMBer
swaybar..
__________________
Pennsylvania has TWO seasons.. Hershey week, and everything else.. LATEST PROJECT |
#17 |
Grenade Inspector
You need more caster in the MII setup. 6 degrees is what I have run in the past.
#18 |
Senior Member
FYI . I've been working to better tune my MII for highway driving . I'm running 4 degrees of caster with the later Mustang ( NOT MII ) power rack. I've installed the shim pack to reduce pump pressure and it does seem to have helped some. But I'm convinced the problem with the overly quick response is not a pressure issue , but rather, a flow issue. I've been going to my local junk yard and have about a half dozen GM pumps from trucks and cars. I've taken the pressure and flow valves from each and there is absolutely no difference . They each have one shim on the pressure valve, and in the flow valve, the flow orifice and return orifice are the same size.
I plan to modify one of the flow valves to reduce the flow orifice size by about 50 % and increase the bypass ( to tank ) orifice by about the same. This should reduce flow to the rack while at the same time allowing the excess flow to dump without dumping over the relief valve. I'll try to remember to post the results. |
#19 | |
Old School HAMBer
Quote:
I don't thing the toe is your problem, I'm not used to seeing it described in degrees though. With bias ply tires, go with a total of 1/8" in, radials you can go with a 1/16" in to zero toe. Bob
__________________
Proud member of the "they closed my thread" HAMB crew. -- BobSS396 ![]() |
#20 |
I'm far (really far!) from an expert, but shouldn't the tie rods be parallel to the lower arms.
To me it looks like the rack needs to be moved higher up.
__________________
Ed |
| Thread Tools | |
| Display Modes | |
