Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 06-02-2012, 08:32 AM   #101
sawzall
Old School HAMBer
sawzall's Avatar
Default Re: MII Directional Stability
I hope I'm right, perhaps if nothing else the bar will mask some of the symptoms.
I just put a rear bar on my 40 wagon and the difference is notable, but a 40 woodie is a great deal taller than A 53 chev...
I hope that you continue to report on the ultimate solution to this problem.
__________________
Pennsylvania has TWO seasons.. Hershey week, and everything else..
LATEST PROJECT
offline   Reply With Quote
Old 06-02-2012, 03:13 PM   #102
rockable
Alliance Member
rockable's Avatar
Bars did not arrive yesterday, so it will be next weekend before I get them installed. I'll keep you posted.
__________________
You Can't Put A Price Tag On A Good Time!
Here is my 41 Plymouth build thread.
http://www.jalopyjournal.com/forum/showthread.php?t=498434
Old 06-02-2012, 04:22 PM   #103
48FordFanatic
48FordFanatic's Avatar
Quote:
I have sway ( or roll ) bars front and rear on mine. It does make a big difference in the handling. I have skipped over a bit of this thread and so I apologize if I'm repeating something already said. If the twitchy /quick handling is your issue, I'm convinced that after trying shims ,etc that too much pressure is not the cause. I believe that as has been said by some, there is just too much flow from the GM pump and when on the highway while trying to go straight the result of the excessive flow is a quick movement of the rack which you end up chasing. If you remove the flow valve from the pump ( not the pressure valve that involves the shims ) you will see a hole about 1/8 inch diameter in the side of the tube section away from the threaded end. This is the flow orifice that allows fluid to flow from the pump to the discharge port. But there is also another smaller hole that is between the threads and the O-ring. This hole is drilled to allow some of the fluid to bypass the discharge port directly back to the tank.
My theory is that shims aside, to reduce flow to the rack you can do one or both of the following. Reduce the size of the flow orifice and , or increase the size of the bypass orifice.
John
Old 06-05-2012, 09:46 PM   #104
rockable
Alliance Member
rockable's Avatar
Shazam! The Chassis Engineering bars made a big difference in the handling of the car. No more jumping and steering itself all over the place and you can drive with much more confidence. I will play with them a little this weekend and see if just one is better than both. Right now it is a big improvement over what I've had. Pictures this weekend.
__________________
Old 07-13-2012, 07:30 PM   #105
rockable
Alliance Member
rockable's Avatar
Just to close the loop on this thread, the Chassis Engineering sway bars made more difference to the handling of this car than anything else I did. It now drives and handles great!
__________________
Old 07-14-2012, 10:37 AM   #106
Grumpys Hot Rods
Newbie
Grumpys Hot Rods's Avatar
Thanks for the update. I have a 1939 ford with mII and have not installed my sway bars.
Sounds like I should off my ass and install my sway bars !!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
