Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#21 |
Grenade Inspector
I really don't understand the need to swap frames on this stuff when there are so many very nice aftermarket suspensions that will go under one of these trucks in a couple of weekends of time.I know every body thinks that because it is a 3/4 - 1 ton that nothing fits.That is not true i actually am doing a 47 1 ton truck for the kid right now and i put a must II under it with no problem.A 71-81 camaro rear axle appears to be the correct width and i am assuming a chassis engineering rear spring kit will get me where i need to be.
When i inspect cars for customers that are purchasing I always have a hard time recommanding that they buy some thing that has had a frame swap or clip put on it.I think they usually look cobbled up.This isn't true in all cases but most. Plus i figure i always have to spend enough time on body work why do i want to waste a bunch of time trying to make some pice of crap of frame work under something that it was never inteaded for? |
#22 |
Alliance Member
I would certainly use the stock frame. As a 3/4 ton it's not that much bigger than a half ton, easy enough to shorten, and easy as hell to sink a Mustang II into. The only way I would EVER consider a S-10 frame swap would be if I was given a cab and bed complete with no frame under it. But even then, these are still so common that the frame are all over the place, so I'm sure I would just grab one and build what fits...
#23 | |
Grenade Inspector
Quote:
__________________
do not buy optima batteries, hecho en mexico! |
#24 |
Newbie
If you have a frame, stick to original. If you think that you have the skills to do a frame swap, you have the skills to mod the stock frame. I am in the middle of an s10 swap on a 51 3100. Its easy enough, but as stated earlier, very time consuming. Good luck with what ever you choose.
__________________
For sale: 2007 sportster in avatar. PM for details. |
#25 |
Old School HAMBer
that's a cool old flatbed. I'd just leave it alone and drive slow.
| Thread Tools | |
| Display Modes | |
