Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Alliance Member
I would love to put a 3spd OD in my 60 Belair. However I am not sure what to look for or where. I did some research but I'm still not 100% sure of the years. Here is what I came up with so far:
3spd OD was first offered in 55 and the same one was used till 57. After that it was offered 58-64 but was different than the 55-57 trans ie, I can't put a 55-57 trans in my car (differnt mounts) I am also wondering how common were these? Are they hard to find? I know there are some electrics and switches involved. Thanks, Todd
__________________
HAMB dealer for Rebel wiring products. 10%discount to all HAMB members http://www.jalopyjournal.com/forum/s...d.php?t=614260 Last edited by Tugmaster; 05-24-2012 at 04:45 PM. |
#2 |
Alliance Vendor
Location: Elmer,Mo.USA All the COOL... people on the HAMB have already been here,why haven't you?
They were also offered in the fully sychronized Saginaws as late as 1967 [CHEVROLETS]that I know for sure
__________________
Running in place, will never get you the results that running from a Lion will.....
#3 |
Alliance Vendor
a GUY NEAR ME HAS ONE HE DID NOT USE THAT HE WANTS TO SELL....
tUGMASTER i THINK THESE sAGINAW od S WERE same length as a 4 speed Muncie
__________________
#4 | |
Alliance Member
Quote:
We're talking 3spd here,correct?
__________________
HAMB dealer for Rebel wiring products. 10%discount to all HAMB members http://www.jalopyjournal.com/forum/s...d.php?t=614260 |
#5 |
Grenade Inspector
I have looked for a while for a reasonably priced one ,-but all i saw at the swaps were big $$$$ ones ,so i am going to do a saginaw 4-speed instead -4 gears on the column and the reverse will be actuated by a cable under the dash ,the guy who did my motor has a 56 ford convert with a 427 -4 speed with this setup .-pretty slick- why dont you just change the gears in your rear
#6 |
Alliance Member
Good point Joe. My stock gears are 3:55. I have room to go down a little. Todd
__________________
#7 |
Alliance Vendor
They are pretty much the same from '55 through '66. The '58 up ones will have the provision for the rear mount. I ran a few in '55-7 Chevys. They work best with 4:56-4:88 rear gears and the gear set from the Corvette. The weak spot is the sprags and drum for the overdrive. You can run them with just a pull cable or lever to activate the overdrive. The wiring and solenoid is only used for the kick down. With the kickdown hooked up it's the poor mans 5 speed. 1st, 2nd out, 2nd in, 3rd out, 3rd in.
#8 |
Old School HAMBer
The later are syncro'd like said above, also the later ones you'll have to modify the shift arms to fit your '60. If you don't care about a syncro'd 1st gear the older ones are almost a direct bolt in (wiring, driveshaft and cable) I have 2 o/d trans, the newer one in my '64 panel truck and the other is an older crashbox that's going in my '60 elco.
Pics are of a later one and an early one, note the shift arms.
__________________
#1 Post killer Last edited by 1oldtimer; 05-27-2012 at 04:31 PM. |
#9 |
Grenade Inspector
Todd, as far as gears go , you could go to 3.36 (my green car has them they are a nice crusing gear ) they are still pretty common ,or 3.08 -easy to swap out the pumpkins ,ive done it a few times on my 50 -right in the garage .
#10 |
Senior Member
Had one and couldn't give it away, went to scrap. search r-10 o/d on google, lots of info and wiring diagrams.
__________________
your old when everything reminds you of a story,,,I have a lot of stories |
#11 |
Alliance Member
Try to find a saginaw OD. Use the same main case as the 4 speed and fully syncro. They are kinda rare and can be pricey at the swap meets. Dont back up if you find one with bad tranny gears. The od unit can be grafted onto the back of a saginaw 4 speed with very little work.
__________________
Just what I need......Another Nailhead! Makin it Git with Old Shit |
#12 |
Alliance Vendor
T-M',
Yes that one I mentioned is here about 20 miles from me....It is a 3 speed Saginaw O/d trans- I personally took it out. It was in a '67 Impala wagon with SBC motor.... I think he wants $350 for the entire deal as I remember....I can get you his phone number if you need it....
__________________
#13 |
FNG
It seems the older GM 55-62 ODs seem to run around $200 - typically. i'm looking for a 55-57 (no rear mount) and have found a couple in this price range - shipping is the real issue.
The kickdown switch is rare and worth big $$. Finding a floor mounted shifter is another issue - I managed to find a Hurst vintage 55-57 OD kit (special mounts and shift linkage) but it ain't cheap. |
#14 |
Alliance Vendor
I wired my kickdown solenoid to a Hurst linelock switch. It worked good at the time.
#15 |
Old School HAMBer
Didn't Chevy use a Ford toploader 3 speed with overdrive in some fuel saver 80's pick-ups? Might be hard to find but a toploader with a chevy bolt pattern would work pretty good...
__________________
www.rumblefest.net www.facebook.com\rumblefestshow www.facebook.com\amherstspeedway |
#16 |
Old School HAMBer
In my experiance the east coast was not a popular place for the OD's.
It cost extra, a lot of small hills, a lot of traffic, noplace to roll fast. In NJ I never saw one in a junk yard in the 60's-70's. Never saw a car with one at gas station/repair places that I worked at either.
__________________
BLASTERS&BEER |
#17 |
Alliance Member
What chevy used was a variation of the chrysler 4 speed. They put an od gear where 3rd was and the one to one gear that was 4th is now 3rd. It used exterior shifting levers and the lever on 3-4 was pointing down instead of up to keep the pattern the same. Tuff tranny but the gear spacing was a little odd.
__________________
Just what I need......Another Nailhead! Makin it Git with Old Shit Last edited by Lobucrod; 05-26-2012 at 04:11 PM. |
#18 | |
Senior Member
Quote:
I think that is that A38o or 383??? I know it was used in some light duty pickups (gm) 80up usually behind a 250-6. I'd like one for my old chevy truck for the 292. be a great combo
__________________
you can have your myspace, facebook and twitter I got the hamb. |
#19 |
just use a later model all synchro three speed...you can pull it into first without completely stopping...a major bonus in traffic....and you could swap rear gears to something like a 3:36 for effortless highway cruising....those old three speed O/D units are hard to find and are not very strong...the later ones are modified 4speeds and have hokey gear ratio spreads....I use a Mopar A230 all synchro three speed in my 52 Ford F1 pickup and I love it....I'm running a 3:92 rear and will never change it because I stay off of the freeways....just local around town.
| Thread Tools | |
| Display Modes | |
