Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Alliance Member
anyone got ideas and pics ?
to put a decent top mount in and get it lined up properly 1954 150 2 door with a little rust but not totalledthis do it yourself stuff is a lot of work ![]() but no money gives you a lot of new skills!!
__________________
disabled nam vet. BSU, MSU , NDSCS , Alexandria Tec. , ASE Tripple Master Tec. |
#2 |
Senior Member
Search "airbag chevy stock front end" there's several good threads on it.
Godspeed MrC |
#3 |
Senior Member
Location: standing in the shadows and pissing in the punch bowl...
Hamber Rusty Pipes did a tech thread on bagging a stock frontend.
#4 |
Alliance Member
doing the rear
too much luggage with OL and spare parts for road trips
__________________
#5 |
Senior Member
The rear is the easy part! Almost any rear bag job can cross over to your ride. Are you still running a torque tube?
__________________
It's not what you buy,it's what you build! Retro Rides-Vintage Rollers C.C. -Central Oregon- |
#6 |
Alliance Member
no torque tube got olds wagon rear
with stock springs looks like i is gonna have to run the pipes under the axle and figure out how to weld a crosmember where the bend is in the frame and weld it in place with the body on with my diabetic hands, burns dont heal looked at your pics nice job
__________________
disabled nam vet. BSU, MSU , NDSCS , Alexandria Tec. , ASE Tripple Master Tec. Last edited by eugene vik; 05-27-2012 at 11:21 PM. Reason: mo info |
#7 |
Grenade Inspector
Check out my build thread on my 54 chev, I followed rustypipes thread and mine went together very smooth and works great. Good luck on your build
#8 |
Newbie
Here is one..
#9 |
Newbie
sorry here is one
#10 |
Old School HAMBer
Eugene, check out Summit, etc. for bolt-in air bag helper kits for drag racing. Guys have been bolting air bags on rear axles to help the launch a lot longer than they have been a mini truck fad...
__________________
Words of Wisdom from an old master... |
#11 |
Senior Member
Yes the rear is easy, look at my thread, I didnt cut the floor, but I also didnt c-notch the frame either. build a bridge between the frame rails and install bags either infront or on top of the rear end, if you place the bag behind the axle you will need to relocate/ or get a different gas tank.
Godspeed MrC. |
#12 |
Grenade Inspector
Damn good tech
__________________
Highway Horrors |
#13 |
Alliance Vendor
here ya go i would put the top bar to the front of the axle like i link # 2 & 3
http://www.jalopyjournal.com/forum/s...d.php?t=152076 http://www.jalopyjournal.com/forum/s...d.php?t=394429 http://www.jalopyjournal.com/forum/s...d.php?t=293280 http://www.jalopyjournal.com/forum/s...d.php?t=202220 http://www.jalopyjournal.com/forum/s...d.php?t=194332 http://www.jalopyjournal.com/forum/s...d.php?t=305649 this one is a ford http://www.jalopyjournal.com/forum/s...d.php?t=394891
__________________
ALIANCE VENDER FOR: ALL YOUR HOT ROD & KUSTOM CAR NEEDS GAMBINO KUSTOMS NOTCHS & TAIL DRAGERS KITS FOR ALL 40'S & 50'S CARS call: 408-561-5744 made a million dollars off my first record deal |
#14 | |
Alliance Member
looked at alexes links great stuff thanks
mr concded looks like that will be the way i will have to investigate, got lots of leftover parts as this stuff never fits so will have to try to get er done this car is a spare driver so i dont want to cut any tin and we have cold weather here i dont need a notch but want to lift this when needed i did the same on my 60 buick and it works well just with the rear i have a mustang front and have a air bag kit that would fit but i may run the lines and controlls but dont think i will put it in right away the front sits way low already about 4 in under the crossmember or less i am gonna put working lakes pipes on this and plan to put them under the rocker panel in height[i think] so thats why i would like to be able to raise this up for clearance Quote:
__________________
#15 |
Senior Member
let me know if I can help, look at my thread for pics of both front and rear setups, there the same thing you are doing.
Godspeed MrC. |
| Thread Tools | |
| Display Modes | |
