Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
FNG
1951 shoe box with a gm sub frame which I assumed was a camaro (bought it installed) with a sb 350 in it. Bought a new set of headers from Sanderson Headers Model CC3 which should fit right in with no clearance problems. Left side no problems with a 2.5 inch pipe going to the collector. The right side I have no room with the starter installed. The end of the starter is about an inch from the A arm with no room on either side for a pipe to go to the collector. The old set of headers that were installed were full length with the collector below and aft of the fire wall. Sanderson doesn't quite understand the clearance problem, I'm going to send them pictures. Has anyone had a problem like this? Maybe it's a nova or S10 sub frame? Sanderson has a set for chevelles that looks like would work but chevells don't have sub's. I,m stumped.
#2 |
Grenade Inspector
Maybe it could be your starter, 168 tooth is larger than the 153 tooth one. the larger flexplate kicks the starter out farther. Hope that helps!
#3 |
Are the engine mounts in the subframe factory locations?
Does the subframe have holes in it where it bolted to the Camaro? I used a '69 Camaro sub and 350 in a '41 Ford P/U and headers for a '69 bolted right in. Although I soon went to cast manifolds because of the effort to keep header gaskets sealed. |
#4 |
Old School HAMBer
Could it be a Nova sub...??? I don't know if there is a difference, I'm only speculating...
R-
__________________
www.RAJetter.com Read about 1960's CAR Chaos AVAILABLE NOW: Faded Thunder Denver ColoRODo stories. |
#5 | |
Grenade Inspector
Quote:
Maybe you should be using Sanderson's header #CS12. That's the one I'm using on my '50 Shoebox with S10 frontend. On the CS12, the collector sweeps back away from and above the starter. The style of the CC3 looks like the collector exits right on top of the starter... doesn't look like that one will work to me. Regards, X
__________________
"We may be lost... but we're making good time." Last edited by xxzzy999; 08-23-2012 at 12:04 PM. |
#6 |
Old School HAMBer
Location: Upstate New York, watching my New Yorker Rust
Someone couldn't cut the front frame out of a Chevelle and use it like a subframe?
__________________
"That was a time when America was great.. when the chrome was thick and the women were straight" - Michael Savage I have old cars for sale. PM me or check the classified. |
#7 |
The Camaro subframe is too wide for the shoebox; I have heard of several people using the 80s Monte Carlo clip and few have tried the Nova or early (rear steer) Camaro sub. You might check to see what the Sandersons for the Monte look like to see if that is the case on your car.
Larry moderator ShoeboxFord Forum
__________________
To invent, you need a good imagination and a pile of junk. - Thomas Edison "Those who expect to reap the blessings of freedom must, like men, undergo the fatigue of supporting it." - Thomas Paine |
| Thread Tools | |
| Display Modes | |
