lowering my Buick *new post-lowering pics added*
Discussion in 'The Hokey Ass Message Board' started by justinsr, May 14, 2013.
  1. justinsr
    justinsr
    from Salem MI
    Strongly thinking about lowering my 57 Buick Special. Does anyone on here have any experience with this particular model?
    I am considering new Eaton Detroit springs made 2" shorter than stock, but I am open to suggestions and or advise. I am not sure if 2" will be enough of a drop and that is as low as they will make springs.
    I drive the car alot and dont want it to ride like a brick but I really am not digging the stock stance!
    thanks in advance for your help!
  2. Fat47
    Fat47
    Less costly approach is to find coil springs with same width and coil thickness but shorter highth and swap them in. There are a number of threads on HAMB with spring conversion charts. Check them out.
  3. Framewelder
    Framewelder
    67-72 Chevy truck rear drop coil springs will bolt right in the rear of those Buicks and you can get them in a bunch of different drops
  4. dubcee
    dubcee
    Do you have a link to these charts you speak of?
  5. justinsr
    justinsr
    from Salem MI
    framewelder,
    What about the fronts?
  6. jasonp
    jasonp
    from Aurora,IL
    I aslo have a 57 Buick Special, but mines on a mid/late 70's GM chassis, just got done doing complete air ride
  7. birdman42
    birdman42
    I was considering cutting a half a coil at a time on the front of my 55 Century.If it rides bad I have another set of springs to replace them.
  8. NAES
    NAES
  9. Bobert
    Bobert
    Just a reminder that the springs in it now are likely sagged by age and the lowering springs you put in may not drop it as much as you think. Experienced that with my Olds which needs to be lower than it is.
  10. hoop98
    hoop98
    from Texas
    Here are some springs that may be of interest to you.
    The 586 is listed as standard, the difference in "compare height" is the approximate drop.
    Remember you only have 3.5 inches of upward wheel travel. If you drop it 2 inches you need shorter installed shocks and trim the bump stops to get some back.
  11. justinsr
    justinsr
    from Salem MI
    Has anyone used the 3" drop springs that Jamco sells?
  12. deadendcruiser
    deadendcruiser
    I used Eaton springs in my 56. Great service and perfect fit. Don't know if the 57 is the same, but mine has pig tail ends, so you can't just cut them down
  13. justinsr
    justinsr
    from Salem MI
    deadendcruiser,
    I looked at Eaton but they only offer a 2" drop while Jamco offers a 3". I was looking for more than 2" drop if possible
    Do you have any pics of your '56 with the drop done you could post?
    Eaton is close to home and I would like to support them but as I stated they only make 2" and I'm worried that won't be enough.
  14. justinsr
    justinsr
    from Salem MI
    So I pulled the trigger and ordered the "3 Jamco springs hopefully I am not disapointed!
  15. robertsregal
    robertsregal
    justinsr, Keep us posted with progress and photos as I'm looking to do something with our 57 Buick also and would like to hear how the process went !
  16. Bagged50Buick
    Bagged50Buick
    80 el camino springs in the rear......cut the fronts.....but very slightly.
  17. oddcraig
    oddcraig
    Let me know how you go. A lot of the info I read on other forums suggested 3" was too much and they had scuffing issues but that was on 54's and 55's.
    Am looking at dropping my 54 so will subscribe to this for sure!
  18. justinsr
    justinsr
    from Salem MI
    Oddcraig,
    What do you mean by scuffing issues? I saw a post by some one on here by I think it was nickrodder who lowered his 3" with a Jamco kit and was very pleased.
    Sent from my SCH-I535 using H.A.M.B. mobile app
  19. hoop98
    hoop98
    from Texas
    Would you mind measuring the free height, coil wire diameter, I am curious if they are close to the GNX spring 5606.
  20. Hnstray
    Hnstray
    from Quincy, IL
    Question: you use the word 'drop' frequently when talking about these springs. Is Eaton Detroit offering a 2" SHORTER spring or a 2" Drop spring? They are not the same thing. A 2" shorter spring will drop the car more than 2".
    Likewise, when you say Jamco offers a 3" drop spring, is that merely a 2" shorter spring that results in a 3" drop or a 3" shorter spring? Terms have specific meaning and, in this case, it would be useful to know which is which.
    Ray
  21. mr.32
    mr.32
    Jamco, service sucks! You pay with order and 2 months later you get your parts. Not good!
  22. justinsr
    justinsr
    from Salem MI
    Hnstray
    I am sorry for the confusing use of lingo. I believe one offers "2 lowering and the other "3 lowering. A
  23. justinsr
    justinsr
    from Salem MI
    Mr.32
    I have read mixed reviews and truly hope I do not have a bad experience. I spoke to Aaron at Jamco and he assured me I will have my springs by the first of July.
    I ordered from them because no one local to me offered 3" drop springs and one guy on here recently ordered the exact same thing for his Buick and was very satisfied.
  24. justinsr
    justinsr
    from Salem MI
    just got a call from the wife and she informed me a big box from Jamco just arrived at the house!!!!
    I can't wait to get home and inspect them.
    Next up the install...
  25. justinsr
    justinsr
    from Salem MI
    New coils ready to install
  26. GearSlammer
    GearSlammer
    from Rogers AR
    sweet! i was thinking about going through jamco to get the same kit for my 54, looks like jamco has improved their service! hurry up and install those puppy's and post some pics!...
  27. justinsr
    justinsr
    from Salem MI
    Looking way better after the spring install!
    Rides a bit stiffer but corners much better!
    Now the search is on for shorter shocks.
  28. GearSlammer
    GearSlammer
    from Rogers AR
    sweet, looks good man.did you have to change out the shocks ?
  29. Looking good..nice to see Jamco getting their shit together...you should bring that Buick out to Midnight Mass
