Projects 31 Kustom Roadster (DIY duvall, tudor to roadster conversion)
Discussion in 'Traditional Hot Rods' started by Chevy28, Feb 13, 2020.
  1. HelminenHotrods
    HelminenHotrods
    from Finland
    Throwing tools is part just of the hobby !
    Stogy and 2Blue2 like this.
  2. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you ! I have to admit i am proud of that. Kind of the meaning of hot rodding or early automotives : Style and the looks, but also functioning and necessary part
    -Markus
  3. HelminenHotrods
    HelminenHotrods
    from Finland
    brEad likes this.
  4. HelminenHotrods
    HelminenHotrods
    from Finland
    Just for fun heres video of trunk lid handle/trim function
    Hope the video works, had some trouble with this new youtube "short"
    -Markus
    dwollam, Parnell, Okie Pete and 6 others like this.
  5. Video worked as well as the handle did! Well done all around.
    Chevy28 likes this.
  6. HelminenHotrods
    HelminenHotrods
    from Finland
    Time for some updates here ! For the last month or two i was working on the stainless steel windshield frame.
    Let's start the process :
    Figuring out the outlines for center post. IMG_20221112_185429.jpg IMG_20221113_184556.jpg
    Need little work to get the right angle: IMG_20221114_185120.jpg
    Then was time for baseplate : IMG_20221115_191717.jpg IMG_20221115_203237.jpg
    Now theres outlines figured and solid, so time to start shaping 1,5mm stainless steel outer skin : IMG_20221117_204152.jpg IMG_20221117_204235.jpg IMG_20221121_211258.jpg IMG_20221121_214823.jpg
    1,5mm stainless steel is real hard to shape. I used handheld airhammer : IMG_20221222_203018.jpg
    After rough grinding and rough polishing it started to look good : IMG_20221124_204056.jpg IMG_20221124_204015.jpg IMG_20221124_204149_Bokeh.jpg
    dwollam, brEad, Shadow Creek and 5 others like this.
  7. HelminenHotrods
    HelminenHotrods
    from Finland
    Upper part for the center post: IMG_20221126_190401.jpg IMG_20221126_190432.jpg
    This need some straightening : IMG_20221126_195413.jpg
    Much better :
    First piece off the windshield puzzle done !
  8. Squablow
    Squablow
    Beautiful windshield post, how did you straighten the bent part?
  9. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you !
    Straightening happened mostly with oxy/acetylene torch. Heat to the opposite side of the bend.
  10. Some real nice work and ideas in this thread !
    Chevy28 and Outback like this.
  11. HelminenHotrods
    HelminenHotrods
    from Finland
    Moving on to the side posts :
    Starting with 7mm SS
    IMG_20221213_195400.jpg I wanted to make something special, something to stand out of "normal" duvall or hallock windshields. So i did an groove to the side post :
    IMG_20221222_202956.jpg IMG_20221222_204247.jpg IMG_20221226_173614.jpg IMG_20221227_203810.jpg IMG_20230102_192804.jpg side post mounting plate :
    And there are side posts almost ready to start figuring out the mounting: IMG_20221226_195653.jpg IMG_20221226_195619.jpg IMG_20230113_231208.jpg
  12. HelminenHotrods
    HelminenHotrods
    from Finland
    I still wanted something more to the side posts, without making it look too thick. So here's what i came up with :
    IMG_20230128_171628.jpg IMG_20230128_171712.jpg IMG_20230131_204243.jpg need some ( a lot ) work to get the angle right when tightening the mounting bolt IMG_20230204_170628.jpg IMG_20230204_191125.jpg IMG_20230204_191135.jpg IMG_20230204_192722.jpg IMG_20230204_191300.jpg IMG_20230204_192747.jpg IMG_20230204_192917.jpg IMG_20230204_192808.jpg IMG_20230204_192812.jpg
    I'm happy how these turned out ! Makes it something different from being "just an duvall copy"
    cactus1, X-cpe, dwollam and 21 others like this.
  13. Martinbuilt
    Martinbuilt
    Those windshield posts are amazing.
    1-SHOT, drdave and Chevy28 like this.
  14. Squablow
    Squablow
    Extra impressive if you carved those trenches into the side pieces with a barrel sander on a hand tool, looks like it could have been stamped or machined in. Steady hand, nice work.
    drdave likes this.
  15. GordonC
    GordonC
    God damn! Now your just showing off! :D Nice job!
    cactus1, Spooky, drdave and 1 other person like this.
  16. HelminenHotrods
    HelminenHotrods
    from Finland
    One of the main goal for me was making it look like casted piece, not like sheetmetal. Details give some "deep" look to it
    dwollam, brEad, drdave and 3 others like this.
  17. Fish plates on the frame for safety’s sake, next to that avatar- oh the irony! Love the build, like the axle stands in the early posts, nice to see things from a different perspective.
    Chevy28 and Squablow like this.
  18. neilswheels
    neilswheels
    from England
    Seriously nice work, stainless is a hard material to work with, in every way, the work in those posts is amazing.
    Chevy28 likes this.
  19. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you ! And thank you for the laugh, you got me there
    Okie Pete and daylatedollarshort like this.
  20. HelminenHotrods
    HelminenHotrods
    from Finland
    Time for the middle parts. IMG_20230207_201047.jpg IMG_20230207_194515.jpg IMG_20230215_195958.jpg
    For the first one did this mounting bolts, hoping it would stay in place/shape, but after welding and heat warp, the bolts were causing trouble so i cutted them off.
    IMG_20230215_200050.jpg IMG_20230215_195909.jpg these really needed straightening with oxy/acetylene after welding: IMG_20230302_192147.jpg IMG_20230304_165205.jpg IMG_20230221_212600_01.jpg IMG_20230221_212552.jpg IMG_20230321_211856.jpg IMG_20230321_212024.jpg IMG_20230227_212842.jpg IMG_20230227_212741.jpg
    GordonC, dwollam, itsmee and 14 others like this.
  21. patsurf
    patsurf
    better change your name to 'duVall'!!
    Chevy28 and GordonC like this.
  22. Wow! Very cool build/thread. Great work! Not sure how I missed it early on...but will be watching for it now.
    Thanks for taking the time to document the process and for bringing us along.
    Chevy28 likes this.
  23. hfh
    hfh
    from Western MA
    WOW! You've made some very nice shapes in your windshield. I would caution you though if you’re going to have a hood on your car, to mock up the hood before you are completely committed to the windshield. When the car has wheels, hood etc. you might wish that you had adjusted some of the shapes a bit. Thanks for sharing your pictures. It’s very nice!
    oliver westlund and Chevy28 like this.
  24. Atwater Mike
    Atwater Mike
    Brent, these are amazing. NOW I want to play with some stainless!!!
    1976, Friend Dave McBride (RIP) cast a pair of ends and a center piece in bronze for my old '29 Highboy.
    I was past the rough sanding, into polish... when Bonneville Butch hastily changed my plans.
    Car was transport to his shop and he and friend 'Uncle Joe' readied it for B'Ville, 1982.
    Okie Pete, Chevy28 and Outback like this.
  25. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you. One thing i should do, is pushing the car outside and take a wider view. It hasn't seen daylight since the tudor days :D
  26. HelminenHotrods
    HelminenHotrods
    from Finland
    Thanks ! I have been thinking about making cast aluminium versions of this
    Okie Pete likes this.
  27. HelminenHotrods
    HelminenHotrods
    from Finland
    Welding pieces together. I did the welds spot by spot and cooling down to reduce heat warpage. IMG_20230328_194622.jpg IMG_20230328_194634.jpg
    After grinding, sanding, polishing : IMG_20230331_223756.jpg IMG_20230331_223914.jpg IMG_20230331_224131.jpg IMG_20230331_224138.jpg IMG_20230331_223954.jpg IMG_20230331_223902.jpg
    Happy to get it finally finished after couple months of almost daily work on it !
    GordonC, Happydaze, dwollam and 19 others like this.
  28. Okie Pete
    Okie Pete
    Beautiful, Your are an old world Craftsman. Thank You for sharing Your build
  29. panhead_pete
    panhead_pete
    That is OUTSTANDING work. Thanks for sharing.
    drdave, Chevy28 and Outback like this.
  30. hfh
    hfh
    from Western MA
    I think getting a look at the windshield outside is a very good idea. Your windshield will be the “star of the show” so be sure that the supporting cast (body, wheels, engine, etc) all work to make this happen.
