Features 41-48 Ford and Merc Picture Thread!
Discussion in 'Traditional Customs' started by nitrobrother, May 1, 2013.
  1. On an acreage near me:
    Dave
    Moondog13, DRUGASM, mgtstumpy and 9 others like this.
  2. airdale6212
    airdale6212
    from Ocala, FL
    This is my 47 coupe project.Has an 8.8 rear and stock front w/disc brakes. Power is a 350/T5. still a long way to go.
  3. NewGuyOldFord
    NewGuyOldFord
    I like your start AIRDALE6212. I like you flip out quarter windows also. Need to find some replacements for mine.
  4. airdale6212
    airdale6212
    from Ocala, FL
    Thanks NewGuyOldFord. Has a long way to go yet but is moving forward slowly. Am lucky the quarter windows are usable but latches need to be rebuilt.
  5. airdale6212
    airdale6212
    from Ocala, FL
  6. i.rant
    i.rant
    1. 1940 Ford
    IMG_0332.JPG Saw this one at the Bunny Run a few years ago.
  7. hotrodyankee
    hotrodyankee
    My 46, took it for its first ride today with the 283 in it. P1010002 (4).JPG P1010002 (4).JPG
    CruznArt, DRUGASM, BigO and 14 others like this.
  8. 504640
    504640
    Great job, Mike! The installation looks clean and the engine is beautiful. Cal custom VC,s? and the matching ribbed air cleaners are a nice touch. Do you have the carbs dialed in? The mint stock interior looks great with the tach on the column! You sure didn't waste any time! Are you planning suspension work, or going to ride stock height?
    rodncustomdreams likes this.
  9. Leadsled52
    Leadsled52
    Here's my heap, I've kind of lost interest on it and havent done much with it in a month or so.
    BigO, mgtstumpy, GhostMN and 6 others like this.
  10. Get back on it man you had it going in a great direction!
  11. hotrodyankee
    hotrodyankee
    Hi, Hope your doing well, was thinking about you the other day. I had this thing running about a month ago after I did the install, and when I first started it, I had very low oil pressure. Took the engine back out and back the machine shop, and found that the 3 pressed -in plugs behind the cam sprocket were loose. we tapped the holes for screw in plugs. Put the engine back in and all is good now. I have it tuned and is a great runner. This winter I'm going to get the axle dropped along with a reversed eye spring and some bigger tires for the rear. The valve covers are cal-customs.
    rodncustomdreams and 504640 like this.
  12. 504640
    504640
    You have got me thinking I ought to scrap the flathead idea for my 46, and use what I already have: a 57 283. The pitted stagger hole, corvette valve covers would fit the patina image the old car already presents.
  13. hotrodyankee
    hotrodyankee
    Well that's sound like another option. Just fair warning, henry ford didn't make it easy on us to hot rod the 41-48 fords!
    504640 likes this.
  14. 504640
    504640
    Yes, but you have the template! I see you kept the battery in the stock position. On my forty, a 283 swap would have necessitated a battery relocation. Also, a swap into a 40 with stock drive line would need the chatter rod issue addressed. You are using the recipe for a classic, traditional, moderate hot rod! I hope you are going to use the stock rims with the red pinstripe!
    Moondog13 likes this.
  15. hotrodyankee
    hotrodyankee
    Thanks, as far as the battery box goes, I wanted to keep it were it was. Using the ram horn manifolds, I had to raise the battery box up 3". Just added to the legs and put a heat shield under it so it would deflect heat from the battery. Need to put on some tube shocks, too spongey.
    504640 likes this.
  16. He told me he'd sell it.. He has a finished one (it was red on the Draggins' car show poster a year or two ago and I have looked through my files for a pic with no luck), so I think the project could be reasonably had. Want me to ask?? Huh, huh?? Hee, hee..
    Dave
  17. I'd be scared to know how much he wants given that most guys up here seem to think everything is gold so something decent must be like a diamond for price.:rolleyes:
  18. ...one of my favorites, Pat Barnhart's coupe...before it became a ragtop...
    CruznArt, DRUGASM, ROCKER77 and 8 others like this.
  19. 59pache
    59pache
    CruznArt, Kage, DRUGASM and 12 others like this.
  20. 59pache
    59pache
    CruznArt, Kage, DRUGASM and 15 others like this.
  21. coupe33
    coupe33
    DRUGASM, cozmic and rodncustomdreams like this.
  22. T&A Flathead
    T&A Flathead
    My convertible is now in progress. I've got a build thread going on it. I'm working on the chop now.
    CruznArt, DRUGASM, Okie Pete and 6 others like this.
  23. LBCD
    LBCD
    DRUGASM, Aussie 48 and 509garyd like this.
  24. DRUGASM
    DRUGASM
    Got the dropped axle, spring, and raised crossmember in. Trying to put some weight on the front to see where it will sit when the motor goes in.
    Kage, BigO, mgtstumpy and 2 others like this.
  25. Arrrrgggghhhh... I, don't, want, to, say, it... Couple 'a big blocks! Whew!
    I do like your sedan and it will look great with the "California rake"!
    By-the-bye, do the Satan's Chauffeurs have a "pop" from time to time? Couldn't help but notice the vast collection of coolers on the shelf..!
    Dave
    DRUGASM likes this.
  26. 59pache, what a great looking coupe! Vanilla never looked better. Do you have any shots of the interior?
    Dave
  27. DRUGASM
    DRUGASM
    Dave -- those are my prepacked travel ice chests. The bottoms are busted so they don't hold water/ice with out leaking. One has a bag of charcoal, a couple lighters, a small bucket BBQ, a couple hot dog sticks, and some soap for clean up. I can grab the ice chest down and toss it in the car and be ready to roll out. The blue metal one still works well. The plastic cheapy ones I used to carry my lunch in when I worked normal people hours.
    Thanks for the encouragement on the sedan. It's coming along. Wish I had more time, more money, and more skill.
    rodncustomdreams and 509garyd like this.
