Art & Inspiration Factory HOT ROD Engines
Discussion in 'The Hokey Ass Message Board' started by draggin'GTO, May 2, 2015.
  1. draggin'GTO
    draggin'GTO
    Straight out of the factory this 1964 389 Pontiac Tri-Power was dressed-up to look perfectly at home between the rails of pretty much any hot rod, as well as under the hood of a Catalina 2+2.
    Chrome valve covers and three small chrome air cleaner lids on the Rochester Tri-Power carbs, typical of what a hot rod engine looked like back then. The Pontiac power-plant engineers really must have been hot rodders at heart, they gave the performance-oriented buying public exactly what they wanted and built some simply beautiful engines.
    Are there any other factory engines you know of that were dressed to impress right out of the box that can compare to this timeless look?
    slack, kiwijeff, 1927graham and 2 others like this.
  2. loudbang
    1963 "R" code 427 FORD. Doesn't get any better than this :rolleyes:
    dana barlow, pat59, kiwijeff and 5 others like this.
  3. OLDSMAN
    OLDSMAN
    You are right on the Pomtiac engine. Right out of high school I bought a 61 Bonneville convertible 389 with factory tri-power, It did not have the small air cleaners, but went to the dealership and bought a set of GTO aircleaners. What a car that was. Brings back a lot of good memories. Of all the cars that I have owned, I wish I had that one back.
  4. Tony
    Tony
    My personal favorite.
    425hp 409
    Chrome rocker covers, aluminum intake with dual quads and plenty of grunt to get anything moving. Lol
    Use the original dual snorkel air cleaner, or swap to a couple small single 4 barrel units and you have instant hot rod motor.
    Tony
  5. squirrel
    Early 60s Vettes had a good looking little motor, chrome air cleaner, aluminum intake, and aluminum valve covers.
    and the Fuelies were even wilder....if you were building a show car....
  6. theHIGHLANDER
    theHIGHLANDER
    Sorry kids, I had to do it...
    kiwijeff, Ned Ludd, 302GMC and 2 others like this.
  7. squirrel
    Way too high class for this crowd :)
  8. Oldsmobile had a tri power motor I don't remember what it was called.
  9. Paul
    Paul
    Editor
    I'm putting together this '58 371 Olds J2 to look close to stock,
    dana barlow, slack, kiwijeff and 7 others like this.
  10. Dyno Dave
    Dyno Dave
    In 1966 a 442 was available with a L69 tri-carb option and a factory select fit ram-air tri-carb W-30 360 hp offering. These cars consistently won classes over the GTO's, set class records and helped Oldsmobile win many NHRA manufactures awards...Dyno Dave
    Hopefully someone can add some photos...
  11. draggin'GTO
    draggin'GTO
    How about we keep this to '64 and older factory hot rod engines, in keeping with the intended scope of the HAMB forums. There were plenty to choose from during those golden years.
    Factory installation, 1963 421 Super-Duty Tempest. Horsepower was underrated at 410 HP with 13:1 compression, this was easily a 500+ HP engine. Perched on top of the 'Bathtub' tunnel ram were a pair of NASCAR 750 cfm AFB carbs.
    A thing of beauty, true automotive art combined with pure race-winning functionality.
  12. FrozenMerc
    FrozenMerc
    Although they were too rare to see many (if any) make it into hot rods, the 1958 Mercury 400 Hp, 430 ci Super Marauder engine would be right at home between the rails of a Duece or A (and have enough torque (490 ft-lbs) to twist it in half too). Polished cast aluminum tri-power air cleaner and chrome baldy valve covers are perfect hot rod material.
    slack, kiwijeff, blowby and 5 others like this.
  13. draggin'GTO
    draggin'GTO
    Wow, probably the most elaborate and expensive factory air cleaner ever to grace a V8 engine. I'm impressed.:cool:
  14. draggin'GTO
    draggin'GTO
    Another example of a Pontiac 421 Super-Duty, a 405 HP 12:1 compression version with the standard low-rise dual-quad intake. Shown here sporting a pair of factory louvered aluminum horsehair air cleaners, the same ones used on the 270 HP 283 Corvettes.
    Looks like a real hot rod mill to me.
    62hotcat, 40fordtudor and loudbang like this.
  15. draggin'GTO
    draggin'GTO
    Dual-quad Cad Eldorado engines?
    Hudson Hornet Twin-H Power flathead sixes?
    Dual-quad Buick 401 nailhead V8s?
    So where are they? o_O
  16. mj40's
    mj40's
    Buick Nailhead with factory 2x4's for me.
  17. Paul
    Paul
    Editor
    finished buttoning up the J2
    all it needs is fluids and a battery and it's ready to run
  18. tubman
    tubman
    Like the "Golden Rocket". What kind of transmission is that please?
  19. Paul
    Paul
    Editor
    thanks!
    the case and shifter are '37 Buick Roadmaster, the gears, guts and tail are from the original selector shift transmission that came behind that engine from the factory
  20. draggin'GTO
    draggin'GTO
    I sure miss those 'Golden Years'. ;) Very nice Rocket you have there Paul!
    Back when you could order the top power options and get a cool multi-carbed mill equipped with some neat factory dress-up items.
    Let's all celebrate those days of 'horsepower freedom', post 'em up!
    Supercharged Thunderbird 312 or Stude 289 anyone?
  21. JimSibley
    JimSibley
    Wow!
  22. JimSibley
    JimSibley
    Was there any factory prewar hot rod motors? Dual carb flatheads, hopped up 6s ect....
  23. FrozenMerc
    FrozenMerc
    Other then some of the high end Factory's (Duesenberg, Cord, Packard, etc), I really don't think there was any concerted effort for the big US manufactors to get into building hot motors. The "Win on Sunday, Sell on Monday" mantra was truly a post war phenomenon.
    The Europeans, on the other hand, had figured out that racing was first, and road cars were second before the war. Companies like Alfa Romeo, Ferrari, and Lancia were all founded by former racers during the pre-war period, and those guys knew how to build some really fast engines.
    The 1934 Alfa P3-B below has a ton of speed tricks on it that were later adapted by hot rodders. Louvers, drilled backing plates, supercharged engine, etc.
    kiwijeff likes this.
  24. indyjps
    indyjps
    The engines posted are how I would build a hot rod. About a 1958 to 1963 timeframe, with a sbc dressed like a guy pulled it straight out of a wrecked car and dropped it into his hot rod.
  25. Gotgas
    Gotgas
    from DFW USA
    Some Mopars...
    1959 Chrysler 300E
    413 wedge 380hp/450tq
    1956 Chrysler 300B
    354 Hemi 355hp/385tq
    1957 Desoto Adventurer
    345 Hemi 345hp/355tq
  26. Gotgas
    Gotgas
    from DFW USA
  27. olscrounger
    olscrounger
    here's one I had for many many years-ran very strong-- it left here about 2 weeks ago-sure miss it too. 57 283/283 Rochester injected Bel Air
  28. FrozenMerc
    FrozenMerc
    1957 Mercury M-335.
    368 ci Lincoln Y-Block.
    335 Hp, 425 ft-lbs
    loudbang and kiwijeff like this.
  29. FrozenMerc
    FrozenMerc
    1957 Ford F-Code Thunderbird
    312 ci Supercharged Y-Block
    300 Hp.
