New SDRA build for tulsa
Discussion in 'HA/GR' started by Mr. Mac, Feb 5, 2016.
  1. Rand Man
    Rand Man
    They look good. Did those others only look warped after you heated them up, or were they screwy from first mount?
  2. Daniel Clark
    Daniel Clark
    Screwy from the start.
    Sent from my SAMSUNG-SM-N910A using The H.A.M.B. mobile app
  3. Mr. Mac
    Mr. Mac
    They sucked from the start Randy, We even had them shaved down to where they were flat but they still would not work. But I will say the other guys use them and they work pretty well for them. They just don't work on our light car. And I love your new car Rand Man.
  4. CrkInsp
    CrkInsp
    from B.A. OK
    If that doesn't fix the problem, you'll just have to quit tipping the can as far.LOL
  5. Old28
    Old28
    What size are the new slicks?
  6. Mr. Mac
    Mr. Mac
    10x15
  7. Rand Man
    Rand Man
    How's it going in earthquake land? Were you able to run it yet?
  8. Mr. Mac
    Mr. Mac
    Things did not go to well for us last Friday night:(:(:( rocker stand failure 002.JPG
  9. bobw
    bobw
    Holy Guacamole! Have you figured out what caused that? Coil bind? Spring pressure? Bad casting?
  10. Old6rodder
    Old6rodder
    from SoCal
    1. HA/GR owners group
    Interesting. Is that a weld bead around the bottom of the broken stand?
  11. Mr. Mac
    Mr. Mac
    Nope it was a brand new head. But there will be a weld bead cause we know a guy that can fix it.
  12. Mr. Mac
    Mr. Mac
    We had an issue with the crank trigger that changed the timing on that run so the cylinder that didn't fire filled with fuel and damage was created Dammit. At least that is what were thinking. I know what you guys are thinking but so far we have found no other damage.
  13. Mr. Mac
    Mr. Mac
    Well after all these months we finally got the head got the head back together. So while we were waiting we built a weight bar for the car to try to help with our traction problem. We also had a stud girdle built hopefully to cure our breaking rocker stud problem. Then the valve cover would not fit over the stud girdle:(:( Now we have to build a new valve cover. Now every thing is back together. Saturday is Tulsa's first test and tune so we planed to take the car out to see how everything works. BUT when we went to adjust the valves this morning plans changed. When we brought it up on TDC on the balancer the piston was not up all the way like when the piston was up the intake valve was open not good. So engine comes out and goes back to the engine builder Friday. God! I love race cars.
  14. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Do you know for sure the balancer outer ring has not slipped? Common. Set the valves on #1 by watching the two rocker arms on #6, likewise by looking at all the other "buddy" cylinders as such:
    153
    624
    1s buddy is 6, 5s buddy is 2, 3s buddy is 4, etc,etc.
  15. Mr. Mac
    Mr. Mac
    Key way sheared on balancer letting it turn and wobble on crank. Balancer was on tight, Of course it screwed up end of(stroker) crank.:(
  16. 1-SHOT
    1-SHOT
    from Denton
    You can drill and tap the crank and put set screws in between the balancer and crank.. I have had to do it on a big block and it has worked for over 100,000. Miles
  17. Mr. Mac
    Mr. Mac
    I will keep your idea in mind,Thanks. The little motor only runs 1/4 mile at a time at around 8200rpm.
  18. 1-SHOT
    1-SHOT
    from Denton
    When I did mine I used a new balancer, and I used 3 screws
  19. Rand Man
    Rand Man
  20. Mr. Mac
    Mr. Mac
    Finally got the engine back together and in the car this last week, All we got left is install the intake and hook up fuel lines. Plan on testing this coming Friday but of course it is suppose to rain. Thank's for asking Randy.
  21. Mr. Mac
    Mr. Mac
    We actually got the car all back together and running. Took it to Tulsa for some testing last Friday night and finally the car hooked up to the tack(100 lb weight bar done the trick) we were happy. Ok, the little car's first pass netted a 11.86 et after my partner(Driver) made a few mistakes getting brain and foot to hook up with gas pedal so probably killed a few tenths or so. So while getting ready for next pass driver notices fuel cap missing Opps! Fueling the car was my job. Well I took the 5th and I no nothing. We all looked up and down the track and never found it so we were done for the night.:(:( I call the car little because here what it looks like up next to another SDRA car. This was a photo opp last year and not racing. Next time sdra car test session 014.JPG
  22. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I like your roll cage.
    safe
  23. Old6rodder
    Old6rodder
    from SoCal
    Looking (and running) good. What wheelbase & curb weight'd you come out at?
  24. Mr. Mac
    Mr. Mac
    118wb 930lbs wet and without driver and weight bar. Still tuning on carbs.
  25. Mr. Mac
    Mr. Mac
    Quick update, We ran the car several weeks ago in Ozark Mo(eighth mile track) ran in the 6.80s. Next stop will be the HAMB drags.
  26. bobw
    bobw
    Wow! a 6.80 1/8 mile ET puts you in the 10's. Great performance for the little car. What's up with the SDRA cars this year?
  27. Mr. Mac
    Mr. Mac
    SDRA guys are going strong, one or two races a month. They took the month of Aug off because of the heat and so far it's been cool:rolleyes::rolleyes:. Our next race is in Ardmore Ok Sept 1. then on to Tulsa at the end of Sept.
  28. Rand Man
    Rand Man
    So I guess you aren't racing at the Tulsa Nitro Nationals today?
  29. 64 DODGE 440
    64 DODGE 440
    from so cal
    Have you been satisfied with the Radir slicks?
  30. Mr. Mac
    Mr. Mac
    They were not bad but still hard. Rule change now let's us run any slicks we want so we went with Hoosiers and boy do they work.
    64 DODGE 440 and Crosley like this.
