Projects Picking up a new old car 55 Plymouth.
Discussion in 'The Hokey Ass Message Board' started by wheeltramp brian, Mar 14, 2024.
  1. wheeltramp brian
    wheeltramp brian
    Just drove this thing about 15 miles and got it up to about 70 cruising, and it drives like a dream but all 4 shocks are completely blown out. So it's all over the place, so I'm gonna try and get some shocks today. If not, I'll drive it home either way. Also my custom cardboard and moving blanket rear seat. 20240426_151112.jpg 20240426_145338.jpg
  2. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Didn’t someone on engine masters build a poly that would kick ass and take names? I had a 55 Windsor. 301 poly but we found out that the 331 hemi heads will physically bolt on along with all the speed goodies. I also had a 241 and a 270 dodge hemi. Both went to a fellow at B ville for the salt. He traded me a 331 hemi complete for the pair.
    I am with the wash it /get it mechanical and ride the xxxx out of it. I do love the look a rough early nascar/ round track look with wide steelies etc. Put wide 5s on it. Killer look.
    And again as others have said. You wasted no time. Maybe just keep riding. All smiles.
    osage orange and Algoma56 like this.
  3. wheeltramp brian
    wheeltramp brian
    Made it almost all the way home within about 5 miles and the generator locked up. I pulled over and took the belt off and found that If I kept it over forty the air coming through the radiator spun the Fan and water pump and it stayed about 3/4 on the temp gauge. I don't have another 6 foot 1. So I'm gonna see if I can swap a 12 vote 1 that I have and just not hook it up to work as a idler, basically. I only gotta go 5 miles down the road to the car show tomorrow.
  4. that is one kool Plymouth,...excellent wheel/tire choice
    Algoma56 likes this.
  5. Jacksmith
    Jacksmith
    from Aridzona
    Now's when the fun starts!
  6. wheeltramp brian
    wheeltramp brian
    So the front bearing is completely junk in the generator but my friend has a 57 parts car down the street. So I've got to go to the kids football game right now and then after that, I'll go snag That thing and see if I can swap the front bearing plate altogether. If not, I have a 12 V generator that maybe the front bearing would be the same.
  7. wheeltramp brian
    wheeltramp brian
    My clubmate in the Wheeltramps was great enough to go and pull that generator while I was at the kids football game and leave it on my porch so when I got home I could swap all the guts out. GoT it all back together and it's working properly and nice and quiet. 20240426_205718.jpg 20240426_210836.jpg 20240426_212009.jpg 20240426_212043.jpg
  8. If you need anything let me know!
  9. I have the radio delete plate and lots of little stuff.
  10. wheeltramp brian
    wheeltramp brian
    I need a headlight and dimmer switch for this thing thanks
  11. Does that oil hole go through to the bearing or is it not drilled through, because I don't see an oiler cap.
  12. caprockfabshop
    caprockfabshop
  13. wheeltramp brian
    wheeltramp brian
    I'll look into those fill caps. Here's a picture of the show before it got packed like sardines. Every open space of
    Ground you see, was Completely packed. The Plymouth made it the 5 miles, no problem LOL. 20240427_075217.jpg
  14. Just saw this, I know the headlight switch is there, I’m sure the dimmer switch is as well. I’ll send ‘em to you for the trip there.
    RodStRace likes this.
  15. Should be an oiler on both front and rear bearings....might even be one on the distributor (GM has them, I don't know about Mopar).
    bchctybob likes this.
  16. Hillbilly Werewolf
    Hillbilly Werewolf
    My '48 has an oil cup front and rear on generator, and one on distributor.
  17. mrspeedyt
    mrspeedyt
    sad that dmv wouldn't let you use the 63 series plates. i was under the impression that if a car had them back then you can continue using them now as long as the previous owner kept the registration current or did the 'non-op' thing.
    i'm a socal native and after my NAVY discharge i moved from cali in 1974 to northern az partially because of the new dmv policies and smog laws.
  18. wheeltramp brian
    wheeltramp brian
    The previous owner kept everything up-to-date and good. They just want more money.
    mrspeedyt likes this.
