new steel stock stroke 351 crank,int. bal. and clearance at .0025 $650 used h-beams 351 stock stroke $300 fresh vertex mag for 351 w/coil $600 new main girdles for 302&351 $100 ea used rousch 0 degree balancer $80 used k/b 351+.040 flattop hyperth. pistons $100 used steel 302 crank and I beam rods $250 dual quad and single quad 302 alum. ints. $80 up single quad 351 alum. ints. $125 up dual point dists. for 302 and 351 $90 up new hi vol. oil pump 351 $40 used crane solid roller cam $200 new comp/cam hyd cam $100 used rocker arm girdles w/poly locs $75 used alum. roller rockers $95 new steel roller tip rockers w/nuts $50 new set protopline alum. heads comp. $800 pending fresh set n351 nascar sportsman heads w/required rockers and pushrods $900 pending 812-453-3003
