SOLD 340 block-.040 over-no crank-rods-pistons-dated-6/28/70 Polished tunnel ram-no carbs New: Stud kit-head and mains Rod and main bearings Cam kit Headman headers with bolts W2 heads-fresh with stands-new rocker shafts-used 1.5 to 1 roller rockers (Can exchange for used X or J heads) Copper head gaskets Gear driven timing gears Harmonic balancer Deep sump oil pan with pick up-no oil pump Used Transistor ignition kit-no coil Used A833 4 speed-68? for b-body Used duel point dist. 4500.00 OBO Will Separate. Ship World Wide Location-Jamestown CA 95327-(USA) [email protected] 209-613-1199-Ca. time Thanks Dave
