Tach drive on a nailhead
Discussion in 'The Hokey Ass Message Board' started by nonipshere, Apr 18, 2024.
  1. nonipshere
    nonipshere
    I have a 322 nailhead that I’m installing in a model A roadster. Has anyone ever used a Corvette generator tach drive set up on a nailhead? If so, what are some technical modifications if any?
  2. 1934coupe
    1934coupe
    I see that no one has chimed in here since yesterday, I believe that if you have the Corvette generator it's just a simple swap of replacing generators. Some generators are longer/shorter than others so the bracket needs to match. That's what I think, good luck.
    Pat
    elgringo71 likes this.
  3. BJR
    BJR
    It should work, but getting the tach to read correctly may require swapping pulleys.
  4. I would imagine your crank pulley will need to be the same diameter as the Corvette one, if it's different then you will be over/under driving the tach. You could be real slick and machine up a bolt on V-groove in the proper diameter that attaches to the Buick pulley and then space out the generator accordingly to line it up if necessary.
  5. BJR
    BJR
    It may also depend on if your tach spins at a different rpm than the Corvette tach for a given RPM on the dial.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    corvette generator drive tachs are 1:1 where dist drive tachs are 2:1, so you will either need a 1:1 tach or a ratio adapter in the cable
    BJR likes this.
  7. BJR
    BJR
    On the 2 to 1 drive which is the 2 and which is the 1? 2 turns on the distributor to 1 on the tach? Or the other way around.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    the distributor turns half the speed of the crankshaft, so the the tach is 2:1
