Test 'n' tune Sydney
Discussion in 'HA/GR' started by spanners, Jul 20, 2016.
  1. spanners
    spanners
    Just when you all thought I'd disappeared up my own exhaust pipe, bad luck, I'm back.
    Things have been a bit quiet due to several race days being washed out and a less than ideal 2200 Drag racing club day.
    There's nothing quite like waiting nearly 2 hours to get a run due to inexperienced track staff only to get to the line, drop the clutch and ...............bang, clunk, rattle. Diff sun gears disintegrate. Back on the trailer.
    Took it back to Sydney the following weekend for a test n tune. I'd changed the diff ratio so was unsure how it would go. I couldn't get it to rev out properly because I'd mucked around with the timing as well.
    Does this rate as a wheels up launch (pure luck really)?
    This is the actual run, pretty sloppy really.
    Tomorrow, I'll put up a video of how the day ended .
  2. 64 DODGE 440
    64 DODGE 440
    from so cal
    Sounds awful good to me Spanners. Almost don't need the 4th gear!
  3. bobw
    bobw
    Looks like it is running real good!
  4. RacerRoy3
    RacerRoy3
    It sure looks like you pulled both to me. Good stuff!
  5. spanners
    spanners
    This is how the first video is supposed to look like. Still trying to work out this slow motion stuff.
  6. spanners
    spanners
    This is how the day ended. Without giving too much away, I've shortened the video to delete some of the expletives.
    I thought the photographer was just being friendly.
  7. Crosley
    Crosley
    from Aridzona
    ah yes. Fun. Sounded like you were about to give a proper weather report of some type. LOL
  8. Hey Spanners, are you coming up to Willowbank for Nostalgias?
  9. spanners
    spanners
    Do ducks fly with their bums pointing at the ground? Of course I'll be there. Come and have a yarn.
  10. 64 DODGE 440
    64 DODGE 440
    from so cal
    This duck used to fly inverted occasionally. Aerobatics are good for the soul. ;)
  11. RacerRoy3
    RacerRoy3
    Sounds like a case of too much Kickapoo Joy Juice to me, 64 Dodge 440. ;):rolleyes::D
  12. 64 DODGE 440
    64 DODGE 440
    from so cal
    Just always had trouble with flying straight and level.
