Tri power rochester end carbs once and for all
Discussion in 'The Hokey Ass Message Board' started by 58_Ford, Mar 24, 2010.
  1. mac762
    mac762
    If it stumbles when you crack the throttle you need a bigger pump shot. Just like the other guy said. Most bogs are lean bogs.
  2. 58_Ford
    58_Ford
    from Phoenix
    How does one increase the gas shot? I used stock accel pumps. Thanks again
  3. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Make sure your getting a full shot from the accel pump. Like I mentioned before, the rubber in the old pumps doesn't like the new gas.
  4. 58_Ford
    58_Ford
    from Phoenix
    Im getting good streams from all 3. I put new accel pumps in a month ago. The neoprene wouldnt fade that quick would it?
  5. Could be an inadequate air bleed. Have had that issue on Harleys and with 2 Carter B&B's on a flathead six. Opened up the air bleeds- no more stumble.
  6. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    On the 3-2's I just rebuilt for a customer the pumps screwed up 5 minutes after the gas hit them.
  7. 58_Ford
    58_Ford
    from Phoenix
    WOW!!! Ive been running fairly good- still really lean. Im going to pull them all apart this weekend and check the pumps. Thats scary. Youd think there would be some kind of effort to stop the manufacturing of them. Could get allot of pro mechanics in trouble.
    I got a 1966 pontiac center carb that Im going to try. Hopefully it will cure the initial stumble
  8. carbking
    carbking
    I have been trying for years to get either of the two major carburetor component manufacturers to make up leather pumps. They won't do it because of costs! We finally gave up, and started making our own leather pumps.
    Neopreme was NEVER even as good as leather, let alone better, but it is about 20 times cheaper!
    Jon.
  9. DeuceDog
    DeuceDog
    from Breese, IL
    I agree but you need to block off the vent by the accelerator pump on all three carbs. Part of the idling problem is the vent is letting to much air in at idle. That's why when the choke is closed, it will idle...less air. Accelerator pumps are needed on the front and back carbs but no idle circuits. Block off all vacuum ports on the front and back carb. Run you vacuum advance from the base on the middle carb.
    Look closely, you see there are no vents on top of the carbs by the accelerator pump linkage.
    DD
  10. DeuceDog
    DeuceDog
    from Breese, IL
    Sorry I was a little late with my comments...didn't realize it was an older thread.
    About the accelerator pumps. If you have a bule skirt wih a spring around the skirt it should work fine with the newer fuels, thats what I was told.
    DD
  11. 58_Ford
    58_Ford
    from Phoenix
    <TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD colSpan=2>DeuceDog, Mine have the blue skirt with the spring. I think Im gonna go leather though. When you talk about the vent by the accelerator pump are you talking about "Idle Vent Valve" on top? I left the one on my center carb because I heard that it helps prevent vapor Lock. Is this the case? Thanks again
    </TD></TR></TBODY></TABLE>
    These are the ones I have
  12. JrFuel
    JrFuel
    from USA
    I'd suggest that you re-think what you just said here, as it is not correct.
  13. 58_Ford
    58_Ford
    from Phoenix
    Just realized, I did my own peeve about forums. Not concluding the result. It runs great. I had to fool with the jets a bit - running 60s in the middle and 55s on the secondaries. Seams to be fine. Dont really have a bench mark. I followed everyones suggestions in this thread and all is well. By the way, To seal the end carbs I sanded a little around the throats and added little lips using jb weld putty. I pulled the carbs off last week -about 8 months later -and they are still holding up. Thanks again for all your help
  14. <!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:punctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if !mso]><object classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui></object> <style> st1\:*{behavior:url(#ieooui) } </style> <![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
    I note in the speedway motors tri power instruction sheet, it states - On smaller cube engines, the amount of fuel supplied by 3 accelerator pumps may cause excessively rich condition when you put the foot down.
    Cutting up to 5 coils on the outside 2 accelerator pumps reduces the shot supplied when the secondary&#8217;s come in.
    Also it recommends #56 main jets for primary and #55 for secondary&#8217;s.
    I am putting together triple carbs on a 283 sbc, with Edelbrock 3x2 intake using Rochester 2G carbs.
    I will try to convert the stock bases by using thicker throttle blades &#8220;laped&#8221; into the small base using valve grinding paste.
    If I can&#8217;t get them to seal I will go for aftermarket bases. As I was looking around for parts I came across - www.pontiactripower.com they have good amount of parts for tri power and the bases look good.
    One thing if interest was DAG213 Throttle Blade Sealer - http://www.pontiactripower.com/shop/category/Carburetor_Parts/
  15. 58_Ford
    58_Ford
    from Phoenix
    Spark, Does the Speedway instruction sheet say anything about jetting for big cube engines? Is it downloadable? Im running a 390 bored .060- That pontiac site is great for rochester tripower info BTW
  16. <!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:punctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> No sorry it doesn’t say. I would highly recommend you send an email to the Mike Wasson – though the site link above. It may take a couple of days to get an answer but he was very helpful. Mike does set ups for the larger base 2Gs and has a lot of parts.
    ;) It wont hurt to mention the some guys from the H.A.M.B recommended you try him.
  17. Von Rigg Fink
    Von Rigg Fink
    from Garage
    my 3x2 rochester set ups ..(i have 2 of them) both end carbs on both set ups are running accel pumps. ..
    I have the progressive linkages set up so that the center carb gets close to little over 1/2 throttle then the front carb starts to come in, and when its at close to 1/2 throttle the rear one comes in and when the center carb roll over to full throttle , all 3 are at full throttle..this might help your bogging..maybe?
    also check and see what jets you are running in your end carbs and be sure when the end carbs are closed, that they arent sucking air past the butterflys..this will cause a vac leak like no other
    and, I would only run a choke on the center carb..period
  18. carbking
    carbking
    Why would cutting coils off of the pump spring change the pump shot???
    If you are using Rochester 2G series carbs, take a look at the pump circuit. The amount of the pump shot is the volume of the pump well displaced by the stroke of the accelerator pump cup in the pump well.
    There are several really easy ways to change the pump shot:
    (A) Note that the pump operating rod (the rod connecting the throttle arm to the intermediate pump rocker shaft) has a bend in the middle. Changing the angle of the bend will change the beginning point of the accelerator cup in the pump well, and thus will change the amount of the accelerator pump shot.
    (B) MANY Rochester 2G carburetors have two holes in the arm of the intermediate pump rocker shaft. This was a factory "summer/winter" pump adjustment.
    (C) And if all else fails, the actual accelerator pumps come in a bevy of different lengths. Both the overall length and the articulated length change. Acquire different length and stroke pumps to help with your tuning.
    And just for the record, cutting coils from the pump return spring might cause the pump not to return as it would weaken the spring. If the spring in question is the articulation spring, cutting coils from this spring would accomplish no change in the pump shot, but if cut too short might just cause the pump to not function period, as the articulation spring pressure MUST be greater than the return spring pressure for the pump to work.
    Jon.
  19. carbking
    carbking
    Spark - here is an article that mentions selecting the carbs to use:
    http://www.thecarburetorshop.com/Aftermarkettripowersetups.htm
    58 Ford - the fuel requirements for a 390 Ford (I have one) and a 389 Pontiac (I had one) are extremely similar. HOWEVER, YOU MUST CONSIDER WHICH CARBS YOU ARE USING WHEN YOU SELECT THE GASOLINE JETS. Many disregard tha fact that a carburetor by definition meters and mixes gasoline AND air. The factorys did a lot of tweaking using different combination of fuel jets AND air jets (the air jets, called air bleeds, are pressed in, and not considered removable by most hobbyists). You can take two carburetors of identical CFM flow, add the exact same gasoline jets, and get two entirely different calibrations if the air jets are different.
    So for a 390 Ford, IF you have a tripower using 389 genuine tripower carbs, the original Pontiac calibration would be a good starting point to begin your tuning. If other carbs are being used; USE THE STOCK CALIBRATION FOR THE CARBURETOR YOU ARE USING AS A STARTING POINT.
    Engineers (at the factory) did things for a reason.
    And here are a couple of 390 pictures:
    http://www.thecarburetorshop.com/Ford_3x2_passengers_side.jpg
    http://www.thecarburetorshop.com/Ford_3x2_drivers_side.jpg
    Jon.
  20. <!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:punctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
    Yep all good info- I was just relating what I had read in the speedway instruction sheet- download- http://static.speedwaymotors.com/pdf/910-11589.pdf
    in my case I am building a 283 using an Edelbrook 3x2 aftermarket intake so the small cubic part court my eye. as far as Rochester 2G go, most of the ones over here would of been on 283, 307,327 sbc. as far getting hold of factory ones...hens teeth! I have managed to get hold of 2 factory end bases and 4 ebay.com.au 2G. really want to do the research and rebuild and refinish the carbs myself, even if it means collecting more ebay carbs.
  21. carbking
    carbking
    Spark - don't know what you might find; but Buick in the early 1960's had a 198 CID 6 that used a Rochester 2-G series. Also, both Buick and Oldsmobile had a 215 CID 8 cylinder that used a Rochester 2-G series. Later (late 1960's into the 1970's) Jeep had a 225 that used a Rochester 2-G.
    Good luck with your project.
    Jon.
  22. Thank you Jon, apart from the Jeep all those cars you have listed were not imported into this country - Chev had an Australian delivered (Canada) from about 1954. W got mostly English cars and from 1948 had our own brand Holden and Australian built Falcons.
    As I understand it the internal difference is in jet size and venturi - would this be a fair statement?
    all the carbs I have look the same and are small base, have the same shaped leavers, all will get new jets, new <!--[if !mso]> <style> v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} b\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} </style> <![endif]--><!--[if pub]><xml> <b:publication type="OplPub" oty="68" oh="256"> <b:OhPrintBlock priv="30E">285</b:OhPrintBlock> <b:NuDefaultUnits priv="1004">1</b:NuDefaultUnits> <b:DptlPageDimensions type="OplPt" priv="1211"> <b:Xl priv="104">7560000</b:Xl> <b:Yl priv="204">10692000</b:Yl> </b:DptlPageDimensions> <b:DxlDefaultTab priv="1504">359410</b:DxlDefaultTab> <b:OhGallery priv="180E">259</b:OhGallery> <b:OhFancyBorders priv="190E">261</b:OhFancyBorders> <b:OhCaptions priv="1A0E">257</b:OhCaptions> <b:OhQuillDoc priv="200E">280</b:OhQuillDoc> <b:OhMailMergeData priv="210E">262</b:OhMailMergeData> <b:OhColorScheme priv="220E">283</b:OhColorScheme> <b:DwNextUniqueOid priv="2304">1</b:DwNextUniqueOid> <b:IdentGUID priv="2A07">0'PLC[E>/&D&'0_('^P[8F`</b:IdentGUID> <b:DpgSpecial priv="2C03">5</b:DpgSpecial> <b:CTimesEdited priv="3C04">1</b:CTimesEdited> <b:NuDefaultUnitsEx priv="4104">1</b:NuDefaultUnitsEx> </b:publication> <b:printerInfo type="OplPrb" oty="75" oh="285"> <b:OhColorSepBlock priv="30E">286</b:OhColorSepBlock> <b:FInitComplete priv="1400">False</b:FInitComplete> <b:DpiX priv="2203">0</b:DpiX> <b:DpiY priv="2303">0</b:DpiY> </b:printerInfo> <b:ColorSeperationInfo type="OplCsb" oty="79" oh="286"> <b:plates type="OplCsp" priv="214"> <b:OplCsp type="OplCsp" priv="11"> <b:EcpPlate type="OplEcp" priv="213"> <b:Color priv="104">-1</b:Color> </b:EcpPlate> </b:OplCsp> </b:plates> <b:DzlOverprintMost priv="304">304800</b:DzlOverprintMost> <b:CprOverprintMin priv="404">243</b:CprOverprintMin> <b:FKeepawayTrap priv="700">True</b:FKeepawayTrap> <b:CprTrapMin1 priv="904">128</b:CprTrapMin1> <b:CprTrapMin2 priv="A04">77</b:CprTrapMin2> <b:CprKeepawayMin priv="B04">255</b:CprKeepawayMin> <b:DzlTrap priv="C04">3175</b:DzlTrap> <b:DzlIndTrap priv="D04">3175</b:DzlIndTrap> <b:pctCenterline priv="E04">70</b:pctCenterline> <b:FMarksRegistration priv="F00">True</b:FMarksRegistration> <b:FMarksJob priv="1000">True</b:FMarksJob> <b:FMarksDensity priv="1100">True</b:FMarksDensity> <b:FMarksColor priv="1200">True</b:FMarksColor> <b:FLineScreenDefault priv="1300">True</b:FLineScreenDefault> </b:ColorSeperationInfo> <b:TextDocProperties type="OplDocq" oty="91" oh="280"> <b:OhPlcqsb priv="20E">282</b:OhPlcqsb> <b:EcpSplitMenu type="OplEcp" priv="A13"> <b:Color>134217728</b:Color> </b:EcpSplitMenu> </b:TextDocProperties> <b:StoryBlock type="OplPlcQsb" oty="101" oh="282"> <b:IqsbMax priv="104">1</b:IqsbMax> <b:Rgqsb type="OplQsb" priv="214"> <b:OplQsb type="OplQsb" priv="11"> <b:Qsid priv="104">1</b:Qsid> <b:TomfCopyfitBase priv="80B">-9999996.000000</b:TomfCopyfitBase> <b:TomfCopyfitBase2 priv="90B">-9999996.000000</b:TomfCopyfitBase2> </b:OplQsb> </b:Rgqsb> </b:StoryBlock> <b:ColorScheme type="OplSccm" oty="92" oh="283"> <b:Cecp priv="104">8</b:Cecp> <b:Rgecp type="OplEcp" priv="214"> <b:OplEcp priv="F">Empty</b:OplEcp> <b:OplEcp type="OplEcp" priv="111"> <b:Color>16711680</b:Color> </b:OplEcp> <b:OplEcp type="OplEcp" priv="211"> <b:Color>52479</b:Color> </b:OplEcp> <b:OplEcp type="OplEcp" priv="311"> <b:Color>26367</b:Color> </b:OplEcp> <b:OplEcp type="OplEcp" priv="411"> <b:Color>13421772</b:Color> </b:OplEcp> <b:OplEcp type="OplEcp" priv="511"> <b:Color>16737792</b:Color> </b:OplEcp> <b:OplEcp type="OplEcp" priv="611"> <b:Color>13382502</b:Color> </b:OplEcp> <b:OplEcp type="OplEcp" priv="711"> <b:Color>16777215</b:Color> </b:OplEcp> </b:Rgecp> <b:SzSchemeName priv="618">Bluebird</b:SzSchemeName> </b:ColorScheme> </xml><![endif]--><!--[if pub]><xml> <b:page type="OplPd" oty="67" oh="266"> <b:ptlvOrigin type="OplPt" priv="511"> <b:Xl>-87325200</b:Xl> <b:Yl>-87325200</b:Yl> </b:ptlvOrigin> <b:Oid priv="605">(`@`````````</b:Oid> <b:OhoplWebPageProps priv="90E">267</b:OhoplWebPageProps> <b:OhpdMaster priv="D0D">263</b:OhpdMaster> <b:pgtType priv="1004">5</b:pgtType> </b:page> </xml><![endif]--><!--[if gte mso 9]><xml> <o:shapedefaults v:ext="edit" spidmax="3075" fill="f" fillcolor="white [7]" strokecolor="black [0]"> <v:fill color="white [7]" color2="white [7]" on="f"/> <v:stroke color="black [0]" color2="white [7]"> <o:left v:ext="view" color="black [0]" color2="white [7]"/> <o:top v:ext="view" color="black [0]" color2="white [7]"/> <o:right v:ext="view" color="black [0]" color2="white [7]"/> <o:bottom v:ext="view" color="black [0]" color2="white [7]"/> <o:column v:ext="view" color="black [0]" color2="white [7]"/> </v:stroke> <v:shadow color="#ccc [4]"/> <v:textbox inset="2.88pt,2.88pt,2.88pt,2.88pt"/> <o:colormenu v:ext="edit" fillcolor="blue [1]" strokecolor="black [0]" shadowcolor="#ccc [4]"/> </o:shapedefaults><o:shapelayout v:ext="edit"> <o:idmap v:ext="edit" data="1"/> </o:shapelayout></xml><![endif]-->accelerator pumps and 2 factory end plates.
    if all my efforts don't result in a driver-able car I will import a set of carbs from Dickster or someone that builds similar set ups.
    I am just trying to add info.
  23. carbking
    carbking
    The key is internal venturi size. The Rochester uses venturii which are cast as a part of the bowl (center section). Jets are removable/replaceable. But you need to start with carbs with the proper internal venturi size for your application. Using matched carbs (at least for the ends) is important as different carbs of the same venturi size could use different air bleeds.
    Jon.
  24. 58_Ford
    58_Ford
    from Phoenix
    Great Info!!!
  25. powdercoater46
    powdercoater46
    I'm rebuilding a Rochester tri power setup for an SBC 355. 4 of the 6 main jets have no size stamped on them and the 2 jets that are stamped 57 measure 54 with a number drill. Do you have any idea what is the correlation between actual drill size and GM jet number? My initial plan is to leave jet size alone and give it a try.
  26. oj
    oj
    A good clue on where to look is that you say it idles fine with choke closed - it should not idle fine with choke closed, it is getting air from somewhere and the previous two guys suggest the 1st & 3rd throttle plates are likely cracked open. There may be more than one problem, like others suggest get it to run off the middle carbs first and go from there.
  27. oj
    oj
    this is a good topic for a similiar but different thread, ok? We've all some some great answers and likely a fair amount of good intended bullshit but we aren't smart enough to respond to two people on the same thread.
  28. powdercoater46
    powdercoater46
    Good one OJ. HAHAHAHA
  29. miraclepieco
    miraclepieco
    Three stock non-tripower carburetors and bases, power valves still intact, home made progressive linkage, outer carbs have idle circuits plugged and butterflies positioned to seal as much as possible - the proof is in the pudding:
    <iframe width="480" height="360" src="http://www.youtube.com/embed/xN4bd8fATF4?rel=0" frameborder="0" allowfullscreen></iframe>
  30. gasserjohn
    gasserjohn
    the dag 213 product was used by the factory<<<!!!
    i'm old enought to have rebuilt carbs on cars untouched? from the factory..........
    did the factory use it or a dealer do it???
