Can you hand Vacuum Bleed the brake system from the bleeder valve at the wheel when you have a @ & 10 lb. check valve and proportional valve in the system? Thanks Jerry
No idea, i do know i like the motive pressure bleeder i have a lot more than the vac bleeders i've had. Much more effective.
