I want to lower the 39 Poncho 2” but can not find lowering blocks that are 2” wide. Anyone have a reference? I’ll also probably be needing pinion shims also, but can likely trim a wider set for those.
I know Nostalgia Sid's Dropped Axles www.droppedaxles.com keeps them in stock but suspect others do as well. Pretty sure he also has narrow shims. That is where I get mine if I don't just build stuff. I don't see them on the website necessarily, but know he keeps them. I would just call 405-416-3080. You won't find better folks to deal with.
Make em? 2x2 aluminium stock. Drill, tap and Allen bolt to provide stud. Drill to provide hole. That's what I do. Chris
Not sure on the block width, but I think trailer springs are 1.75", so these 2" tall solid steel blocks might be an option?: https://simcoespring.com/products/2in-trailer-lift-block-kit?variant=45879080386728
You might want to check with Butch's Cool Stuff: https://www.hotrodhotline.com/butchs-cool-stuff-quality-line-1928-1965-custom-and-rodder-parts I put a pair from them in my old Coronet and they fit well. This was probably over 10 years ago now, I'm not sure if they are still around.
That's the way I made them. Drill a small 1/4" hole clear through, then open one side up for locating hole, and drill and tap for Allen cap screw on the other side. I also weld a plate on each end just to close them up.
I just go to the steel yard and dig through the drop bin for steel square tube, put a 1/4" bolt through the center for a centering pin and call it a day. Ubolts are cheap on ebay.
