32 and model a ford filled roof what are you using
Discussion in 'The Hokey Ass Message Board' started by 32coupedeville, Nov 7, 2010.
  1. 32coupedeville
    32coupedeville
    from cincy
    post up pics or your roof filled , recessed panel. what are us using . tell us what car you have and what the roof came off of.
  2. AG F/C
    AG F/C
  3. cracker head
    cracker head
  4. fast30coupe
    fast30coupe
    from Illinois
    roof from a 50 shoe box has a good contour
  5. landseaandair
    landseaandair
    from phoenix
    I think this type of thread has been done before. One I've tried is a Maverick skin turned backwards on an A coupe, perfect fit.
  6. 32coupedeville
    32coupedeville
    from cincy
    i did a surch but i could nt find anything. i have know about the mavrick turned around backworks . i wanted to see id any one was using any thing else . it is hare to find a good mavrick roof that hasnt had another car stacked on it here in ohio or that didnt have a vinyl top about rusted off. i have used in the past a dodge extended cab roof off a 80's truck on a model a. also used a decklid oof a 6 cadillac but it had a peak down the middel. it worked for what i was building, 32 hupmobile .
  7. Reds 29
    Reds 29
    I used a roof off a 72 Vega station wagon, it's got 6 beads down it. Probably won't be easy finding one of those. It needed a bit of work to fit correctly. It's on my 29 Ford coupe.
    Red
  8. scrap metal 48
    scrap metal 48
    How about louvers.......
      520 KB
  9. Flipper
    Flipper
    from Kentucky
    Anybody recognize this roof? it was on a 32 at the Pumpkin Run.
  10. rexrogers
    rexrogers
    inserts from Walden's one we put the factory step in it so an original cloth material can cover keeping the stock look
    the factory joggle on this one was good the Walden insert was trimmed up to match
  11. 40LUV
    40LUV
    from Mid Jersey
    Flipper,
    Those roof inserts with the beads just in the center were from Mopar station wagons. Not sure of the exact models or years, but I think early 1960s.
  12. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    Before Waldens I use a piece of top from a Corvair coupe turned backwards to do a deuce 3 window.
  13. jackandeuces
    jackandeuces
    I have used a number of corvairs , on 32, 33, 34 coupes 57/58 ford on sedans, 68 Mustang ,cougar on A' coupes....
  14. used a section of a 61 chevy roof to fill the hole in my a coupe
  15. We filled the insert on a rough old 33 Chevy by making some curved strips of sheet metal and tacking them together after the initial metal work with a shrinker-strecher and then tacked them into place.
    We started with a sheet of 20 gauge cold rolled steel.
    We had never used a English wheel but that didn't stop us from trying,,:rolleyes:
    We have a lot to learn and it is far from being or looking professional but after working it further with a body hammer in spots,,some filler it turned out pretty good. HRP
  16. 32coupedeville
    32coupedeville
    from cincy
  17. djust
    djust
    from Oklahoma
    Used the top off an old mercury wagon turned around backwards for my 29 A sedan.
    I worked our pretty good, has 5 ribs in it and was able to use the original braces to.
  18. Jeff Norwell
    Jeff Norwell
    MODERATOR
    What Jack sez....:)
    Corvair 2 door roof....... perfect crown.
  19. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Hrp!/lovely work !!!!!!
  20. Clark
    Clark
    The narrow set of ribs on the 32 sedan is early 60's Mopar wagon. I have one from a 62.
    Clark
  21. big duece
    big duece
    from kansas
    Now that's bad ass!!
