Ford rear end ID question......
Discussion in 'The Hokey Ass Message Board' started by briggs&strattonChev, Nov 27, 2003.
  1. briggs&strattonChev
    briggs&strattonChev
    Hey guys, I have a 68 ford galaxie 500 XL convertible that im building. My parts car is a 68 LTD with a 9 inch, but the convert doesnt have a 9 inch (I dont think so anyway). It has a removable pan on the back, and I dont think the 9 inch had that so thats my reasoning. On the tag it says:
    W R A (Ford)
    3.10 6DD 1
    Thats what I think it says anyway, its kinda corroded. There are 10 bolts holding the pan on too if that helps.
    Anyone know what rearend this is? Is 3.10 the ratio im guessing?
  2. the correct rear end doesnt have the cover, the late 70- 80's lincolns, etc did. My 68 XL has a coil spring style 9", I dont recall ever seeing any full size cars even pre 79 with a cover. I dont know the type of rear that is, I dont deal with them. The 3.10 is most likely the ratio, See if there are any numbers on the carrier, starting with D or E, that would put in the 70-80 range. I would go with the right 9", but thats just me. [​IMG]
  3. briggs&strattonChev
    briggs&strattonChev
    yeah, id rather go with the 9 inch too, but my parts car 9 has 2.73 gears, and I think that might be a little too high.
    got any pics of your XL man?
  4. TINGLER
    TINGLER
    Hey briggs,
    Here is a link to some info: it may help ya...?
    FORD 9 CLICK HERE
    JT.
  5. briggs&strattonChev
    briggs&strattonChev
    by the way, the convert with the mystery rear end had a factory 302, maybe only big blocks got 9 inchers?
  6. lakes modified
    lakes modified
    Iv'e heard that there were some 8" rears with the cover, but still had a dropout 3rd member. could be one of them. doubt you ever seen to many of them tho. the 9" should fit also. measure your spring mounts center to center to see if there the same as the 9". i would bet there the same.
  7. FEDER
    FEDER
    I also am stumped on the back pan model.Dana 60 out of a truck? But Im sure the rear end out of the LTD will be a 9 and 3/8" unit and NOT a 9".Pull the axle and you will find 31 splines. The 9 3/8 chunk is not as strong as a 9".But will work fine for an everyday driver.---Feder
  8. Fat Cat
    Fat Cat
    Well I just looked through my list of axles and codes. I did not find the code you posted but I did come up this,
    WER-A
    Ford Passenger 1967-69
    3.10 ratio
    31 tooth ring gear
    10 tooth pinion
    8 1/2 dia ring gear
    Non-Locking
    Non-Removable Carrier
    This rear really doesn't have much in the way of usablity for a performance application. Also you are going to have a hard time finding parts for it. I think it is a Dana unit.
  9. 67Imp.Wagon
    67Imp.Wagon
    Don't know about the #'s but I have a 78 granada rearend that is a Ford 8.8 and it has a rear removable cover and it looks real similar to the Dana. Might check to see if it's an 8.8
  10. flavored
    flavored
    from kindersley
    hi there wondering if you still had the 68 ltd parts car, looking for a rear window
  11. Uh, you know this thread is 10 years old?!
  12. Holy old post revival Batman :eek:
  13. junkyardjeff
    junkyardjeff
    Even though this thread was started over 10 years ago some of the full sized Fords had a rear end that was not a 9 inch starting around 67,just because its a full sized car does not mean it has a 9 inch so if you are looking at a car to donate the drivetrain look at it first. I bought a 70 galaxie for its 351-w and it had that rear end and I think there were used up to the end of the 9 inch era.
  14. Does this break the record on resurrection? I didn't know the archives even went back that far. That Ford was nearly new back then..:rolleyes:
  15. s55mercury66
    s55mercury66
    from SW Wyoming
    Time for the 20 year anniversary bump
    Deuces, SS327 and Beanscoot like this.
  16. manyolcars
    manyolcars
    uh, you know that it doesnt matter if this thread is 10 yrs old. I got a Crosley starter from an 8 year old ad.
  17. It's 20 now!
    Deuces likes this.
  18. s55mercury66
    s55mercury66
    from SW Wyoming
    I had a guy join the HAMB, and PM me about a taillight I had posted a thread in a thread several years earlier. Not quite 8 years though, maybe 3.
  19. Mr48chev
    That's better than the one that joined just to PM me claiming that he was selling first class parts on Ebay when I stated in a thread that his low priced eEbay parts were Hoffman group junk and that he used Hoffman group photos and adds in his Ebay adds .
