Technical Setting Angle of Engine/Transmission to Pinion Shaft
Discussion in 'The Hokey Ass Message Board' started by gatz, Aug 11, 2025 at 1:12 PM.
  1. gatz
    gatz
    At present for this 40 Chrysler build, the engine/transmission are located in the chassis with rear end not yet positioned, that is; spring perches have not been welded to axle tubes yet, but the rear end is attached to the springs and located left/right while axle can still be rotated.
    What would be the tolerance for setting the angle?
    Can it be set when the body is NOT mounted to the chassis, or should it be when the body IS mounted and all other components in place as a complete car?
    Doublepumper and chryslerfan55 like this.
  2. Doublepumper
    Doublepumper
    from WA-OR, USA
    I do it when the car is complete, for a more accurate measurement.
  3. alchemy
    alchemy
    Ya kinda knew that would be the best answer, right?
    RICH B, Bandit Billy and 1971BB427 like this.
  4. BJR
    BJR
    There are lots of threads on this subject, all say set it at ride height. The search function is your friend.
    mgtstumpy likes this.
  5. RodStRace
    RodStRace
    Yeah, this has been the subject of an epic amount of threads. Please use search! Just go with "Angles" and In Title. That should give you enough.
  6. 1971BB427
    1971BB427
    from Oregon
    Most people want to try to do it too soon, then end up using wedges, or reworking mounts when it doesn't work. I have done it before the engine was in by piling cement or sand bags across 2x6 boards in the engine bay, and making sure I had the weight close. Otherwise wait until it's close to done to set pinion angle. Some small things can be done afterwards, but not heavy things.
    Robdski and Doublepumper like this.
  7. Doublepumper
    Doublepumper
    from WA-OR, USA
    ^ Yep on the too soon. That's why I know to wait for last:eek::oops:
  8. lostone
    lostone
    from kansas
    Yep, agree, search engine, do it last....
  9. gatz
    gatz
    OK, then
    Thanks for confirming.
  10. Just playing devil's advocate here. What if you set it up all perfect like, then drive it from L.A. to New York with Granny and 2 kids in the back seat. Is the driveshaft going to fall out?
  11. 1biggun
    1biggun
    Nope thats why there is a U joint in the first place .
  12. LWEL9226
    LWEL9226
    from So. Oregon
    Everyone has answered when to set angle, but no one has given the tolerance for the angle between trans and axle....
    LynnW
  13. Kerrynzl
    Kerrynzl
    Just set it up now, but do 4 spot welds on the top of each of the perches. [guess the ride height to what you want]
    Then get on with the rest of the build.
    You can cut the spot welds later and make adjustments if needed
