Technical Two pedals or three
Discussion in 'The Hokey Ass Message Board' started by DDDenny, Jul 13, 2025.
  1. wheeldog57
    wheeldog57
    The first car I bought at 15 years old was an automatic. The second car was also an auto but I changed it to a 4 speed. Every car I've built since has been a stick.
    Currently building a 33 5 window with a Cadillac and turbo 400. . . . . Don't tell anyone
    05snopro440, ffr1222k, SS327 and 5 others like this.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    My Impala is way more fun to drive since I tore out that girls transmission and put a 4 speed in it IMG_4715.jpeg
  3. Phil P
    Phil P
    Every vehicle we own has 3 pedals. I've only had 2 automatics in my life. When I make fun of someone else's automatic I really am kidding, to each there own.
    Phil
  4. Here we go, all the guys with a clutch sticking their chests out waiting on a medal acting like they belong up on Mt. Rushmore lol
    I have automatics, one is manual shift only, the others I can leave it in "D" or lock them in manual mode.
    I used to drive truck in the city for a living, probably pushed that clutch pedal 6,000 times a day for decades. The last thing I wanted to do was push a clutch and shift gears to go home, I've had multiple surgeries on my left knee and for the past six years I have to get injections in it every 90 days.
    So for any of you chest thumpers that think I'm a pussy for having automatics remember that I've shifted more gears than you'll ever shift driving around in your wannabe he-man macho machines.
  5. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    Collecting parts to convert my 56 from 2 to 3 if that answers the question… :D But, my fast(er) car has always been an automatic with a 4000 stall too.
  6. Sharpone
    Sharpone
  7. 19Eddy30
    19Eddy30
    from VA
    Was A 3 pedal Rodder Racer until I found cubic inches & Torque ,
    Then a few broken M22 many 21s
    Before 20
    Most average 4&5 speeds,450 tq is max
  8. 49ratfink
    49ratfink
    learn't myself how to drive at 16 with a six cylinder and 3 on the tree in my 49 chevy. later my good buddy got a 56 Chevy with a 4-speed. I drove it out to what was at the time farmland and the junk yards along with Fremont Dragstrip so he could learn how to use a clutch.
    he told me to do a burnout so I did and when I shifted I got my first of many second gear scratches.. I was hooked!
    later I got an OT car with a big block and 4 speed and had more fun in that car than any other car I have owned since.
    that was in the old days when muncie 4 speeds and posi rear ends could be found at the junk yard. I broke one of each. stick shift is just more fun.
    good times!
  9. As I’ve had soft cartilage in both my knees since I was 18 years old two pedals work well for me.
  10. I build low hp crap
    the 3rd pedal makes it more fun
    A 235 and an auto kinda sounds boring. And expensive
    My bus is auto though.
    Told a guy it was stupid low cause my knees were bad
    Traffic and bad knees changing gears is fun
  11. 19Eddy30
    19Eddy30
    from VA
    True on Big Trucks ,
    Going to bust some Nuts ,
    Running into quite a few Cdl drivers ,
    That Can Not drive Stick ,
    Because they do not know how ,
    witch I am a custom of Manual ,
    I thought a Family member not to long ago how I drove truck ,
    Only using Clutch when take off ,
    Took drive Test , instructor wanted to Double clutch , Then went for drive Job
    Company wanted double clutching also
    In there Manual trucks.,
    Back to Hot Rod , Race Rod
    I will eventually get back to havering a Manual.
    G Force
    Jericho
    TKX
    Lenco
    B & J
  12. gene-koning
    gene-koning
    The same BS, different day.
    A guy has to be pretty quick at shifting a manual trans to out shift a properly set up automatic transmission. The hard reality is, very few can actually do it. The guys that can't actually out shift that auto transmission feel a need to belittle those that drive the faster shifting auto transmissions. That attempt at belittling the drivers of the automatic transmission is even less effective these days then it was in the 60s.
    I've had both manual and automatic transmissions (still do have one of each that I usually drive). Thirty years ago I could shift a manual 4 speed trans pretty fast (and the Mopar Hemi 833 trans was pretty tough), but I was not nearly as fast as those auto trans could shift, even back then. These days, my left knee, and the really slow, internal shaft, shifting 5 speed continues to tell the true story, most manual transmissions shift much slower then a properly build automatic transmission.
    The 5 speed is more fun to drive, until my knee starts hurting, then its not so much fun anymore. When I finish a 500 mile road trip with the automatic transmission in my truck, I'm in a lot less pain then I am after driving that same 500 mile trip in the manual transmission car.
  13. lostn51
    lostn51
    from Tennessee
    How about the best of both worlds…..
  14. Sharpone
    Sharpone
    Ronnie Sox’s kryptonite, how are they on the street?
    Dan
  15. lostn51
    lostn51
    from Tennessee
    Believe it or not the transmission I posted is advertised as a street version.
  16. hrm2k
    hrm2k
    I’ve always wanted a stick hot rod. My old coupe was an automatic, my V8 Corvair is a TH425 automatic. If I ever finish my 1917 RPU, it has a 5 speed. Exciting but not motivating
  17. 19Eddy30
    19Eddy30
    from VA
    Lenco S T 1200
    New around 8k ish
    It can be used with Converter
    Or 1-6 clutch in Can ( Bell housing)
    Other Options a Slipper
  18. hrm2k
    hrm2k
    I hope you clocked those screw heads on the shifter boot so they match :rolleyes:
  19. lostn51
    lostn51
    from Tennessee
    Amazing how pushing a clutch seems so much easier now :D
  20. 49ratfink
    49ratfink
    the "belittling" is not a real thing, it's all in fun. nobody really cares if a person has an auto transmission.
    went to an all Mopar show yesterday, in my world every Cuda, Superbee, GTX, Roadrunner etc in the show was much more cool when I saw that pistol grip sticking up from the floor. same with any other high performance factory car regardless of make.
    Rickybop, partsdawg, lostn51 and 4 others like this.
  21. 61s are always more fun when you row them, lol 453747808_18408114814076672_3352555562327439630_n.jpg
    Most of my vintage stuff is all sticks. Since they are fun weekend and non every day rigs its a nice thing to go through the gears. My 33 is an auto but that was for when it was bracket racing for points everywhere. Hard to beat the consistency of a automatic shifting when your drag racing. Both have their place and sometimes its just nicer to have a auto depending on what your actually doing.
  22. 19Eddy30
    19Eddy30
    from VA
    Few other High Tq & Hp
    Manual gearbox ,
    lostn51, Ned Ludd, GasserTodd and 4 others like this.
  23. Mr48chev
    Unless you are 78 frigging years old with a left knee that gripes every time you push a clutch pedal and two of my rigs are 3/4 and 1 trucks with 4 speeds and heavy clutches and the plan for the 48 is a stick behind the 292 but my knee is campaigning for an automatic.
    Yuppers, the guys who only drive to the coffee shop and back once or twice a week with their stick and don't do hours on end in traffic working a clutch are always the ones who bad mouth guys who run automatic because their knees survived jumping out of helicopters and off sailboats and years on end on concrete floors. I love the idea of having the 5 speed I have for my 48 but my left knee is a lot happier when it doesn't have to push a clutch pedal on the way to somewhere where I will be walking for several hours.
  24. Dave G in Gansevoort
    from Upstate NY
    Direct drive, no clutch, only in or out. Use the starter to warm up the engine. Kill it and engage the box. Get the push truck to get you rolling, turn on the magneto, then the fuel. Make sure you are pointing in a good direction! And hang on!
    lostn51, Sharpone, Rickybop and 3 others like this.
  25. Rickybop
    Rickybop
    Looks like Mark got a rise out of a couple of you fellas. LOL. He's just pretending to be an asshole. Although, he does a pretty good job of it. :D
    I'm sure there aren't many of us who actually think that we're any better or manlier cuz we're bangin' gears. It's just a preference or sometimes necessity dictates. Fact is, I'm just a little concerned about how smart I'm gonna have to get to set up my clutch linkage. I'll handle it. But you know... it's not the easiest thing in the world. Another thing... I'm 68 and I hope I can still work the clutch and the shifter when I finally get the darn thing on the road. Better start exercising.
    SS327, Sharpone, hrm2k and 2 others like this.
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    Yeah, I’m just kidding about the girls car stuff…. I do have 600,000 miles commuting in daily drivers with manual transmissions. Plus every single one of my old cars that I drive are stick shifts. Like Ricky says get out and exercise. I have put 2000 miles on my vintage schwinn 10 speed this year so far
  27. 2OLD2FAST
    2OLD2FAST
    from illinois
    Tell us how you really feel .,.
    swade41 and 49ratfink like this.
  28. Bandit Billy
    Bandit Billy
    You painted a picture there sir! My dick did that turtle thing as my sphincter slammed shut. Good post. good post.
  29. Mine can pull way more logs out of the woods than those wimpy drag cars
