what is this transmission???
Discussion in 'The Hokey Ass Message Board' started by madpole, Jan 19, 2008.
  1. madpole
    madpole
    numbers are T96-1S WG DIV5 serial #s may be 1H85?? main housing is only 7" long. total length w/tailshaft is 17 1/4".
  2. chaddilac
    chaddilac
    Looks like the one from a 3/4 ton Ford pickup?
  3. 6deucecaddy
    6deucecaddy
    or maybe a 3/4 ton chevy pickup
  4. Pir8Darryl
    Pir8Darryl
    It's a Werner T-96 3 speed.
    Used in 4 cylinder Jeeps, Willis, Nash, and Rambler's
    Produced from WWII up thru early to mid 60's.
  5. madpole
    madpole
    thanks guys. i think pir8darryl is correct!!
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    They were even used behind Buick/Olds 215 V8s.
  7. Pir8Darryl
    Pir8Darryl
    I'm a bit rusty here, so dont take what I'm about to say as fact, but if I recall correctly...
    T96 - 1S, 4 cylinder 2 wheel drive
    1R, 4 cyl 4 wheel drive
    1L, 6 cyl and small v8 4 wheel drive [early waggoner and 215 V8]
    1C, 6 cyl and small V8 2 wheel drive
    WG - "western Gear", Californiia foundry and plant
    DIV 5 - Denotes which production line the case was destin for
    18H- The last week of August, 1951 or 1961
    5 - Friday.
    It's been 20+ years since I was into that stuff. [I used to be an engineer at GM]
    But if I'm not mistaken, you have a Warner 3 speed thaat was made on Friday, the last week of August in 1951 or 61, in the Cal. plant, and was made to be installed in a 4 cylinder jeep or Nash
  8. flatblackstude
    flatblackstude
    from carver, ma
    Hi,
    I searched T96 and found this thread. I was hoping to find something on dropping an old Jeep 3-speed shifter on it. To make it floor shift, currently it's column shift. I bought one awhile back and have been told that it is relatively easy to do. Anyone done it?
  9. fweiner
    fweiner
    from Warrens WI
    Is There any one who has aT96 1s transmission for sale that In good shape. Willing to pay a good price.
  10. steel rebel
    steel rebel
    Pretty much the same tranny. used in Ford Econoline trucks sixty's and seventy's. Have one in my roadster. Yes just pull out the side shift forks, plug the holes, take off the top plate and drop a Jeep shifter right in.
